PropertySets Failing to Access iProperties
richard.joseph.pollak
I am trying to compare expression values in my iProperties, but some of the default iProperties have been giving me trouble.
Does anyone know why I am getting an error?
oPropSet = ThisDoc.Document.PropertySets.Item("Design Tracking Properties")
MessageBox.Show(oPropSet.Item("Description").Expression)
MessageBox.Show(oPropSet.Item("Project").Expression)
MessageBox.Show(oPropSet.Item("Checked By").Expression)
'The following returns an error:
MessageBox.Show(oPropSet.Item("Eng. Approved By").Expression)
Here is the error:
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
   at Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
   at LmiRuleScript.Main()
   at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
pball
It seems that isn't the correct item name. My cheat sheet shows "Engr Approved By".
Here is a copy of the iProperties list from an AU pdf I found.
Now that I think about it, I remember having this issue before because the label in the iProperties dialog do not match the item name in the API.
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
search = True
i = 1
Do While search = True
	Try
		MessageBox.Show(oPropSet.Item(i).Name)
	Catch
		search = False
	End Try
	i = i + 1
Loop
I was able to trouble shoot using the rule above. I learned that the name of "Eng. Approved By" is actually "Engr Approved By".
Go figure! Hopefully if anyone else comes across this problem they will find this post.
