Prompted entry text in inserted symbol
k14348
k14348
I would like to give value for prompted entry fields which is in inserted symbol.
Sub RevisionTb()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSheets As Sheets
    Set oSheets = oDoc.Sheets
    Dim oSheet As Sheet
    Set oSheet = oSheets.Item(1)
    oSheet.Activate
    Dim oSketchedSymbols As SketchedSymbols
    Set oSketchedSymbols = oSheet.SketchedSymbols
    Dim oSketchedSymbol As SketchedSymbol
    Set oSketchedSymbol = oSketchedSymbols.Item(1)
    Dim oSketchDef As SketchedSymbolDefinition
    Set oSketchDef = oSketchedSymbol.Definition
    Dim oSketch As DrawingSketch
    Set oSketch = oSketchDef.Sketch
    Dim oTextBoxes As TextBoxes
    Set oTextBoxes = oSketch.TextBoxes
    Dim oTextBox As TextBox
    Set oTextBox = oTextBoxes.Item(1)
    Dim oText As String
    'Prompted entry text <Date>
    'Set Value for this Date = DateTime.Now
    '    'Prompted entry text <Drawn>
    'Set Value for this Drawn ="kk"
    'Repeat this process to all sheets
End Sub
YuhanZhang
Here is the sample VBA code:
Sub RevisionTb()
    Dim oSheet As Sheet
    oSheet.Activate
    Dim oDate As String
    oDate = Format(Date, "MM/dd/yyyy")
    For Each oTextBox In oTextBoxes
    If oTextBox.Text = "Date" Then
    Call oSketchedSymbol.SetPromptResultText(oTextBox, oDate)
    Exit For
    End If
    Next oTextBox
    'Set Value for this Drawn ="mka"
End Sub
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
