Project workplane from an assembly to a sketch in a part
jiri.paur
jiri.paur
I am tryring to project a workplane geometry from an assembly to a plannar sketch i a part.
Anybody who can help me?
Private Sub projectGeometryWP(colWP As Collection, coloOcc As Collection)
    Dim oWorkPlane As WorkPlane
    Dim oOcc As ComponentOccurrence
    For Each oOcc In coloOcc
        Call oOcc.Edit
        Dim oSketch As PlanarSketch
        On Error Resume Next
        Set oSketch = oOcc.Definition.Sketches.Item("Stender")
        If Err.Number <> 0 Then
            Set oSketch = oOcc.Definition.Sketches.Add(oOcc.Definition.WorkPlanes.Item(1))
        On Error GoTo 0
        Call oSketch.Edit
        For Each oWorkPlane In colWP
            Call oSketch.AddByProjectingEntity(oWorkPlane)
        Next oWorkPlane
        Call oSketch.ExitEdit
        Call oOcc.ExitEdit(kExitToTop)
    Next oOcc
End Sub
JhoelForshav
Hi @jiri.paur
What you need to do is to create a proxy object for the skecth. If the workplanes aren't in the top level assembly you need to create proxies for them as well.
Here's a very simple example on how to project a workplane from the main assembly into a sketch named "Sketch 1" in a partoccurrence named "Part1:1" in the assembly.
'Get the active assembly
Dim oAsm As AssemblyDocument
Set oAsm = ThisApplication.ActiveDocument
'Get a part occurrence in the assembly
Set oOcc = oAsm.ComponentDefinition.Occurrences.ItemByName("Part1:1")
'Get the sketch in the part
Set oSketch = oOcc.Definition.Sketches("Sketch 1")
'Create a proxy for the sketch
Dim oSketchProx As PlanarSketchProxy
Call oOcc.CreateGeometryProxy(oSketch, oSketchProx)
'Get the plane in the assembly
Dim oPlane As WorkPlane
Set oPlane = oAsm.ComponentDefinition.WorkPlanes.Item("XY Plane")
'Project the plane into the sketch
Call oSketchProx.AddByProjectingEntity(oPlane)
'Update the assembly
oAsm.Update
jiri.paur
Thank you Jhoel! This is exactly what I needed (proxy of the sketch) 🙂
I believe, there is no way to keep associativity of the projected geometry for this case (Assembly -> Part), right?
JhoelForshav
Hi @jiri.paur
I'm glad to hear it helped! 🙂 And yes, unfortunately in this case adaptivity isn't possible. You'll get the same unadaptive result if you project the plane manually as well 😕
