Project sketch onto curved surface
meck
meck
I have a 2D skecth that I need to project onto a curved surface using code. Can someone please give me a starting point. I've searched here and the programming help, but I cannot find anything but embossing and decals.
Also can someone clue me in as how to search ONLY this forum. I keep setting the search to Board, but it doesn't matter. I'll get results from every Autodesk forum. This is extremely frustrating and time consuming trying to wade through AutoCAD, 3DS max, and general Inventor posts.
I'm using Inventor 2013 and iLogic.
Thanks.
Mike Eck
Master Drafter/ CAD Programmer
Using Inventor 2018
philippe.leefsma
Hi Mike,
I doubt this is possible ... Do you mean you would like to project all 2d entities in a sketch onto a surface?
In Inventor 2014, a new functionality was added to create intersection curves between entities, so you could extrude the 2d sketch entities as a surface and intersect that with your surface. For previous releases of Inventor, I don't see a way to achieve that.
Here is the VBA sample and a pic of the result:
' This sample demonstrates several new curve creation techniques
' introduced in Inventor 2014. It creates a new part and then
' create a 2d control point spline and a 2d equation curve. ' Surfaces are created from these two curves by extruding them.
' A 3d intersection curve is created between the extrusions.
Public Sub SketchCurves() ' Create a new part. Dim partDoc As PartDocument Set partDoc = _ ThisApplication.Documents.Add( _ kPartDocumentObject, _ ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject)) Dim partDef As PartComponentDefinition Set partDef = partDoc.ComponentDefinition ' Create a 2D sketch on the X-Y plane. Dim sketch1 As PlanarSketch Set sketch1 = partDef.Sketches.Add(partDef.WorkPlanes.item(3)) Dim tg As TransientGeometry Set tg = ThisApplication.TransientGeometry ' Create a spline based on control points. Dim pnts As ObjectCollection Set pnts = ThisApplication.TransientObjects.CreateObjectCollection Call pnts.Add(tg.CreatePoint2d(2, 0)) Call pnts.Add(tg.CreatePoint2d(4, 1)) Call pnts.Add(tg.CreatePoint2d(4, 2)) Call pnts.Add(tg.CreatePoint2d(6, 3)) Call pnts.Add(tg.CreatePoint2d(8, 1)) Dim controlPointSpline As SketchControlPointSpline Set controlPointSpline = sketch1.SketchControlPointSplines.Add(pnts) ' Create a 2D sketch on the Y-Z plane. Dim sketch2 As PlanarSketch Set sketch2 = partDef.Sketches.Add(partDef.WorkPlanes.item(1)) ' Create a spline based on an equation. Dim equationCurve As SketchEquationCurve Set equationCurve = sketch2.SketchEquationCurves.Add(kParametric, kCartesian, _ ".001*t * cos(t)", ".001*t * sin(t)", 0, 360 * 3) ThisApplication.ActiveView.Fit ' Extrude the 2d curves. Dim prof As profile Set prof = sketch1.Profiles.AddForSurface(controlPointSpline) Dim extrudeDef As ExtrudeDefinition Set extrudeDef = partDef.features.ExtrudeFeatures.CreateExtrudeDefinition(prof, kSurfaceOperation) Call extrudeDef.SetDistanceExtent(6, kSymmetricExtentDirection) Dim extrude1 As ExtrudeFeature Set extrude1 = partDef.features.ExtrudeFeatures.Add(extrudeDef) ' Change the work surface to not be transparent. Dim surf As worksurface Set surf = extrude1.SurfaceBodies.item(1).Parent surf.Translucent = False Set prof = sketch2.Profiles.AddForSurface(equationCurve) Set extrudeDef = partDef.features.ExtrudeFeatures.CreateExtrudeDefinition(prof, kSurfaceOperation) Call extrudeDef.SetDistanceExtent(9, kPositiveExtentDirection) Dim extrude2 As ExtrudeFeature Set extrude2 = partDef.features.ExtrudeFeatures.Add(extrudeDef) ' Create a new sketch and an intersection curve. Dim interSketch As sketch3d Set interSketch = partDef.Sketches3D.Add Call interSketch.IntersectionCurves.Add(extrude1.SurfaceBodies(1), extrude2.SurfaceBodies(1)) End Sub
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
meck
Thanks Philippe that looks like what I need. I guess I'll have to put the program on hold until next year. My company upgrades every other year. Thanks again!
Mike Eck
Using Inventor 2018
