Project name in Inventor windows title
BenjP
Message 1 of 14
BenjP
Hi all,
I posted a question in the Inv discussion group. Can anybody help with this?
http://forums.autodesk.com/t5/Autodesk-Inventor/Project-name-in-top-bar/td-p/2928998
I have no knowledge of VB.
Replies (13)
Message 2 of 14
Mike.Wohletz
Extract the attached into a folder like C:\Program Files\Autodesk\Add-ins  or some other of your choice and run the install 32 for 32 bit machines or install 64 for 64bit machines and start Inventor and I think you will have what you are looking for..
Message 3 of 14
BenjP
Hi Mike!
This is perfect!!! Smiley Happy
Thanks a lot for your help!!!
Message 4 of 14
Mike.Wohletz
To make life easier I have made this with an installer and uninstaller.
 This also has the source code with it as well.
Message 5 of 14
Dan_Margulius
Hello ,
I installed the progrm but it is not working...I have inv2010 and 2011 pro.
On both I dont see the project name.
help...
Dan
Message 6 of 14
BenjP
Hi Dan,
just unzip the folder from the message before into the "Addins" folder on your c drive.
Inventor is looking for a file with and "dll" or "addin" extension in that folder.
Inv will start this addin on every start.
Also, make sure that you're add-in manager has the addon in it and loads it on start up. (see attached pic)
Message 7 of 14
Dan_Margulius
Thanks for helping,but still its not working.i built a folder and put the files there and installed even but there is no addin in inventor like in your picture.
Message 8 of 14
BenjP
Dan,
what kind of windows version do you have? (I have Win7.)
It's a folder that Inv creates itself when installed.
It might be different for others windows.
Also, if you can't find your add-in manager go to
Start menu - All programs - Autodesk - Autodesk Inventor 2011 - Tools.
In there you'll find the add-in manager.
Message 9 of 14
Dan_Margulius
Wait....Wait....I see it in INV 2011.
Can this work with 2010?
Dan
Message 10 of 14
BenjP
Sorry can't give you an answer on this...
Message 11 of 14
Mike.Wohletz
Please uninstall the previous version and install the one attached and let me know if that fixes the problem in 2010..
Message 12 of 14
Dan_Margulius
Hello Mike,
In 2011 it works but not in 2010. the addin appears but is always unloaded. Even if I load it and get back to addins later
again the checkbox load/unload is unchecked.
Dan
Message 13 of 14
Dan_Margulius
But this is good enough for me that is working in 2011.
R.
Dan
Message 14 of 14
sjxyz
Fantasti! Many thanks Mike
