Project File Mapping
All,
I have the code stated below, I was hoping you could help with a few things:
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 24470 StartFragment: 314 EndFragment: 24438 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
Sub Main
    iLogicVb.RunRule("CustOn")
'query user
MessageBox.Show("Would you like to print to the current Project File?: ", "iLogic Question",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
'set condition based on answer
If question = vbYes Then
    oFileName = ThisDoc.FileName(False) 'without extension
    oRevNum = iProperties.Value("Project", "Revision Number")
    Else
    ' Get the PDF translator Add-In.
    Dim PDFAddIn As TranslatorAddIn
    PDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
                            ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
    'Set a reference to the active document (the document to be published).
    Dim oDocument As Document
    oDocument = ThisApplication.ActiveDocument
     Dim oContext As TranslationContext
    oContext =  ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = kFileBrowseIOMechanism
    'Create a NameValueMap object
    Dim oOptions As NameValueMap
     oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    ' Create a DataMedium object
    Dim oDataMedium As DataMedium
    oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
    ' Check whether the translator has 'SaveCopyAs' options
    If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        ' Options for drawings...
        'oOptions.Value("Launch_Viewer") = launchviewer
        oOptions.Value("All_Color_AS_Black") = 1
        'oOptions.Value("Sheet_Range") = ThisApplication.PrintRangeEnum.kPrintAllSheets
        oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
        'oOptions.Value("Remove_Line_Weights") = 0
        'oOptions.Value("Vector_Resolution") = 400
        'oOptions.Value("Custom_Begin_Sheet") = 2
        'oOptions.Value("Custom_End_Sheet") = 4
    'get PDF target folder path
    oFolder = Left(ThisDoc.Path, InStrRev(oPath, "\")) & "PDF"
    'Check for the PDF folder and create it if it does not exist
        If Not System.IO.Directory.Exists(oFolder) Then
            System.IO.Directory.CreateDirectory(oFolder)
     'Set the PDF target file name
    Dim fname As String
    fname = oFolder & "\" & oFileName & " Rev" & oRevNum & "-CUST.pdf"
    oDataMedium.FileName = fname
    'Publish document.
    If  System.IO.Directory.Exists(fname) Then
        System.IO.File.Delete(fname)
        MessageBox.Show("Earlier PDF deleted! ", "Inventor")
    PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
    MessageBox.Show("Print Created in default Projects -  "  & fname, "Inventor")
End Sub
First I was hoping I could have the project name added after the question in the project file. Also I was going to try and set up a browser the would pop up if you were to hit no where you can manually map the file where you'd like it to save?
Any ideas? I am pretty new to all of this and its getting a little too complex for my experience.
machiel.veldkamp
I made somthing VERY similar just last week!
Check out this topic: you can ask me any questions whatsoever.
http://forums.autodesk.com/t5/inventor-customization/automated-pdf-export-question/m-p/6577551#M6696...
___________________________
Gosh that is helpful! But I am kind of lost..
First, where did you input your changes?? and also I was hoping to make it so it would print all the sheets as individual PDFs
I am really new to the extensive coding, I do more if then and suppression codes Smiley Indifferent
This is the updated code... But I still cant distinguish the yes/no and how to map when no is selected.
 Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 38787 StartFragment: 314 EndFragment: 38755 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
Sub Main
    Dim IPJ as String
    Dim IPJ_Name As String
    Dim IPJ_Path As String
    Dim FNamePos As Long
    'set a reference to the FileLocations object.
    IPJ = ThisApplication.FileLocations.FileLocationsFile
    'get the location of the last backslash seperator
    FNamePos = InStrRev(IPJ, "\", -1)
    'get the project file name with the file extension
    IPJ_Name = Right(IPJ, Len(IPJ) - FNamePos)
    'get the project name (without extension)
    IPJ_ShortName = Left(IPJ_Name, Len(IPJ_Name) - 4)
    'get the path of the folder containing the project file
    IPJ_Folder_Location = Left(IPJ, Len(IPJ) - Len(IPJ_Name))
    MessageBox.Show("Would you like to print to the current Project Folder?" & vbLf & "Project Name:" & IPJ_Name _
    & vbLf & "Project Path:" & IPJ_Folder_Location _
     ,"iLogic Question",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
    Dim i As Integer
    Dim fname As String
    Dim PrintedSheets as String
        For i=1 To ThisDrawing.Document.sheets.count
            ActiveSheet = ThisDrawing.Sheet(ThisDrawing.Document.Sheets(i).Name)
            fname = oFileName & "-sht"& i  & "-Rev" & oRevNum & " .pdf"
            printedSheets = fname & vbCrLf & printedSheets
            printsheet (oFolder,fname)
        Next i
        'iProperties.Value("Custom", "2Shop ShtTotal")= Chr(i + 64)
    MessageBox.Show("Print Created in default Projects -  " &  oFolder & " \" &  vbCrLf & vbCrLf & printedSheets , "Inventor")
End Sub
Function PrintSheet(sheetPath As String, sheetName As String  )
        oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintCurrentSheet
    oDataMedium.FileName = sheetPath & "\" & sheetName
    'Publish document.
    If  System.IO.Directory.Exists( sheetPath & "\" & sheetName ) Then
        System.IO.File.Delete( sheetPath & "\" & sheetName )
End Function
machiel.veldkamp
Public Sub Main()
	Dim oPath = ThisDoc.Path
	oDuctName = iProperties.Value("Project", "Description")
	oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	Dim oDWGAddIn As TranslatorAddIn
	oDWGAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}")
	oDrafstman = ThisApplication.UserName
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	oDataMediumPDF = ThisApplication.TransientObjects.CreateDataMedium
	oDataMediumDWG = ThisApplication.TransientObjects.CreateDataMedium
Dim FolderNameLoc As String
'Declare projects in the "2016" Projects Folder
Dim oChoice
Dim ProjectChoice As New ArrayList
ProjectChoice.Add("HOME") 'Drawings will be saved on a seperate location
ProjectChoice.Add("ProjectExample1")
ProjectChoice.Add("ProjectExample2")
oQuestion2 = InputListBox("Project specification - in doubt select HOME", ProjectChoice, ProjectChoice, Title := "CHOOSE PROJECT", ListName := "ProjectChooser")
FolderNameLoc = Mid(oPath, InStrRev(oPath , "\"))
If oQuestion2 = "HOME"
oFolder = "C:\TEMP\INVENTOR\Save As PDF DWG location\" & oDrafstman & "\"
Else
oFolder = "C:\TEMP\Projects\"& oQuestion2 &"\Specific Foldername"& FolderNameLoc & "\"
'PDF Setup If oPDFAddIn.HasSaveCopyAsOptions(oDataMediumPDF, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 0 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 500 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets End If ' DWG SETUP - Check whether the translator has 'SaveCopyAs' options If oDWGAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "G:\folder\INVENTOR\iLogic\Save as DWG aparte sheets.ini"' THIS PIECE IS NECECARY> CREATE A .INI FILE FROM AUTODESK AUTOCAD FIRST AND MAKE A SET THIS LINE TO THAT INI FILE> ' Create the name-value that specifies the ini file to use. oOptions.Value("Export_Acad_IniFile") = strIniFile End If 'get target folder path If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If 'Set the destination file name Dim fileName As String fileName = ThisDoc.FileName(False) & " - " & oDuctName & " - REV " & iProperties.Value("Project", "Revision Number") oDataMediumDWG.FileName = oFolder & fileName & ".dwg" oDataMediumPDF.FileName = oFolder & fileName & ".pdf" 'Ask the User if he wants PDF or PDF+DWG oQuestion = MessageBox.Show("For PDF select YES for PDF+DWG select NO", "PDF or PDF/DWG", MessageBoxButtons.YesNoCancel, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1) 'Publish document. If oQuestion = vbYes Then oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMediumPDF) Else If oQuestion = vbNo Then oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMediumPDF) oDWGAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMediumDWG) Else 'MessageBox.Show("Canceled", "We're doing nothing now...") End If If oQuestion = vbYes Or oQuestion = vbNo Then OpenFolder= MessageBox.Show("Would you open the folder?", "PDF EXPORTED", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1) 'open the folder where the new files are saved If OpenFolder = vbYes Then Process.Start(Proc, Args) Else 'Return End If Else End If End Sub
Alright. This should kinda do 'the' EDIT NOPE. Make an .ini file for the dwg export first EDIT trick for now. First thing monday morning i'll grab my copy at work and fix this bit so you can also select a custom folder.
So if this works as intended you should get a few notifications.
(/\ PIECE OF CODE)This questionbox grabs the input of the array that I specified above ( protip: make projectname for yourself)
	'Ask which project the User uses
	oQuestion2 = InputListBox("Choose where the exports need to be saved to", ProjectChoice, ProjectChoice, Title := "CHOOSE PROJECT", ListName := "ProjectChooser")
(/\ PIECE OF CODE)This Questionbox  Does what it says inside the (" TEXT") piece of code. It's in english now. (whoops)
(/\ PIECE OF CODE) See how to read lines of code now?
Also. Look through the API a lot. Read through the things you want to use.
Try and search for:
I have a working piece of code at work that I can't acces at the moment that will do more than the code shown above.
for now. This is the best I can do. I'm no expert so forgive me for the lack of information 🙂
