Model is Not Update
Model is Not Update
Pratik.Ksoni
Model is Not Update
Pratik.Ksoni
i have attached one Parametric Model and in this model from drop down list all volume are update but  when i change 1500 volume then model is not update and for update the model i have to run the rule.
Please guide me and provide me rule to update model automatic without run the run.
Pratik
machiel.veldkamp
you can set triggers in your model.
You can even set a trigger for a iLogic rule when the geometry of your model changes.
If you do that, every time you change some geometry the iLogic rule will Run.
Is that what you want?
___________________________
Pratik.Ksoni
Hi Mark,
i tried but still it couldn't update, could you please use my model and guide me?
you help will be highly appreciated.
Pratik
Pratik.Ksoni
Hi Mark,
Now it works well.
Thanks for your Help.
Pratik
