Project edge of a curved surface to 2d Sketch
A.Acheson
Mentor Mentor
A.Acheson
Hi All, Running into a block on trying to project an edge of a cylinder face to a 2d sketch. I can do this manually by selecting the edge but can't seem to be able  to find the method by API. I am able to get the vertical edges but not the horizontal edge. Any help appreciated.
	Dim oFace As Face = ThisApplication.CommandManager.Pick _
  					(SelectionFilterEnum.kPartFaceCylindricalFilter, "Select a face")
   Dim oPartDoc As PartDocument = ThisDoc.Document
   Dim Set1 As HighlightSet = ThisApplication.ActiveDocument.CreateHighlightSet
   Dim oCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
   Dim oSketch As PlanarSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes(3))
	oSketch.Edit
	Dim oLine1 As SketchLine = oSketch.AddByProjectingEntity(oFace.Edges(2))
	Dim oLine2 As SketchLine = oSketch.AddByProjectingEntity(oFace.Edges(1))
Regards
Alan
Andrii_Humeniuk
Hi @A.Acheson . I couldn't find a method to project a curved surface, but in case you can't find a solution, then I suggest just creating a new line based on two points of the projected lines.
Dim oDoc As Document = ThisApplication.ActiveDocument
If TypeOf oDoc Is PartDocument Then
	Dim oPDoc As PartDocument = oDoc
	Dim oFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceCylindricalFilter, "Select a face")
	Dim oCompDef As PartComponentDefinition = oPDoc.ComponentDefinition
	Dim oTM As TransactionManager = ThisApplication.TransactionManager
	Dim newTM As Transaction = oTM.StartTransaction(oPDoc, "CreatSketch")
	oSketch.Edit()
	If oFace.SurfaceType = SurfaceTypeEnum.kCylinderSurface Then
		Dim oVertLine1 As SketchLine = oSketch.AddByProjectingEntity(oFace.Edges(1))
		Dim oVertLine2 As SketchLine = oSketch.AddByProjectingEntity(oFace.Edges(2))
		Dim oGorzLine1 As SketchLine = oSketch.SketchLines.AddByTwoPoints(oVertLine1.StartSketchPoint, oVertLine2.EndSketchPoint)
	oSketch.ExitEdit()
	newTM.End()
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
WCrihfield
Just an FYI.  This situation is exactly what the PlanarSketch.AddBySilhoutette() method is good for.  The tricky part is specifying a point on that face nearer to one side or the other, in order to specify which side of the cylinder you want to project.  You could simply use the Face.PointOnFace, which will work for one side, then just mirror that accross the cylinder's axis, but I don't know if that would remain fully constrained.  Or use the PlanarSketch.ProjectedCuts.Add method, if the plane goes through the center of the cylinder.
Wesley Crihfield
(Not an Autodesk Employee)
