Project 3d Sketch into 2d sketch
I have a 3D spline i'm trying to project into a 2d sketch on the XZ plane. The spline is the only object in the 3d sketch.
I have found vba api codes that show how to project the center point or an axis but nothing about a sketch object.
Is this possible through the api? I'm coding in VBA.
Thanks in advance for any help.
If anyone every looks at this I figured it out and it's super easy.
SyntaxEditor Code Snippet
    Dim oSketch As Inventor.PlanarSketch
    oSketch = oPartDef.Sketches.Add(oPartDef.WorkPlanes(2))
    ' Project 3D Spline
    Dim oSpline As SketchSpline
    oSpline = oSketch.AddByProjectingEntity(Spline3D)
Where Spline3D is the spline created in the 3D sketch. Doing it this way allows you to constrain other 2d sketch objects to the projected spline.
