Programming technique, to speed up loops?
omartin
omartin
So I have a simple loop to remove the overrides from a partslist:
ThisApplication.ScreenUpdating = False
For Each plr In pl.PartsListRows
    plr("col1").Static = False
    plr("col2").Static = False
    If plr("col1") = "" Then
    plr("col1").Value = "No"
Next plr
ThisApplication.ScreenUpdating = true
as expected on small assemblies there is no issues, on larger ones it is not a huge delay but noticeable as well as mouse flickering.
question is when editing the parts list manually, and then hitting ok, the changes seem to be almost instant after hitting ok.
My guess is when iterating through the steps, it is like hitting the "ok" button at the end of each loop.
Is there a more efficient way to perform such a loop, where all the changes are done and then applied in "one shot" (for a lack of better description) like modifying the table manually and then hitting the ok button?
Was my reply Helpful ? send a Kudos or accept as solution
YuhanZhang
Can you try below code if it helps?
Dim oTransaction As Transaction
Set oTransaction = ThisApplication.TransactionManager.StartTransaction(ThisApplication.ActiveDocument, "Edit Partslist")
Next plr
oTransaction.End
ThisApplication.ScreenUpdating = True
It wrap your multiple edit to the partslist in a custom transaction.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
omartin
Thanks for the reply Rocky, It didn't speed it up any, however; the transaction is really helpful and I will start using.
I was trying to create a datatable to mimic what i want to change but it wasn't working out...
If there was another built in object that represents the parts list as a flat table, or some way to access the PL as a datatable or something where i could just update text would be good, maybe I will add that to the feature request.
YuhanZhang
How about if set the DeferUpdates:
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim bDeferUpdate As Boolean
bDeferUpdate = oDoc.DrawingSettings.DeferUpdates
oDoc.DrawingSettings.DeferUpdates = True
Set oTransaction = ThisApplication.TransactionManager.StartTransaction(oDoc, "Edit Partslist")
Next plr
oTransaction.End
oDoc.DrawingSettings.DeferUpdates = bDeferUpdate
Rocky Zhang
Inventor API PD
Autodesk, Inc.
omartin
That did speed it up a bit (~5 secs from my hand stop watch) not as instantaneous as editing the table but I guess it is the closest we can get.
It would be good to know how the partslist works (pragmatically) encase I wanted to make a custom partslist editor...
Thanks Rocky
