Procedure in iLogic
Procedure in iLogic
abilabib
Procedure in iLogic
abilabib
How to create and use procedure in iLogic.
I have try for create simple procedure / function in iLogic but can't work.
function LOD (ByVal a as string) as DrawingView
ThisApplication.FileManager.GetLastActiveLevelOfDetailRepresentation(a)
end function
LOD_Assy = LOD(DirName)
xiaodong_liang
Autodesk Support
Autodesk Support
When you define a procedure, you need to define Main procedure for the main workflow. And if a procedure is a function, you need to make sure to provide a return value for the function. Please refer to the code snippet below.
Sub Main()
  Dim DirName As String
  DirName = "c:\Assembly2.iam"
End Sub
Function LOD (ByVal a As String) As DrawingView
   Dim oLODStr As String
   oLODStr = ThisApplication.FileManager.GetLastActiveLevelOfDetailRepresentation(a)
   'just to make sure the prcedure is called
   MsgBox(oLODStr)
   ' do your job to get a drawing view...
   ' remember  assign the drawing view to the
   ' function name LOD as the return value
   ' LOD = .....
   'I set it to nothing just for demo
   LOD = Nothing
End Function
abilabib
Thanks for your reply.
I'll try Smiley Wink
