2013 Inventor Viewer PrintToFile() Prints to Printer.
What the heck?!!
The 2013 Inventor Viewer PrintToFile(<FileName>) procedurePrints to the printer.and not the file.
2011 worked fine,  Same code used.  2013 fails to print to the file, and prints to the printer instead.
Pulling what little hair I have left out over this one.
--- Shortened version of code follows ---
If oView.FileName = "" Then Exit Sub
Dim oDwg As IV.ApprenticeServerDrawingDocument = CType(oView.ApprenticeServerDocument, IV.ApprenticeServerDrawingDocument)
Dim oPrnt As IV.ApprenticeDrawingPrintManager = CType(oView.ApprenticeServerDocument.PrintManager, IV.ApprenticeDrawingPrintManager)
oView.Interactive = False
With oPrnt
  .SetCurrentView(oView.ClientView)
  .Printer = "PDF File Creator"
  '.Printer = "\\SERVER05\Kyocera Mita KM-4035"
  Dim oSheet As IV.Sheet = oDwg.Sheets(1)
  .SetSheetRange(1, 1)
  .PaperSize = InventorApprentice.PaperSizeEnum.kPaperSizeLetter
  .Orientation = InventorApprentice.PrintOrientationEnum.kLandscapeOrientation
  ScaleMode = IV.PrintScaleModeEnum.kPrintBestFitScale
  .PrintToFile("C:\PDF_Home\Sheet-1.ps")
End With
Sorry to alarm anyone.  The problem was run-time and difficult to debug.
Someone set their default PDF output folder in my app to a name different from that which existed.
In my code (Ported from VB6) there was a "On Error Resume Next"  in the PS (Postscript) output loop.
When the non-existing folder name as part of the full output full name was passed to
oPrnt.PrintToFile(<fullfilename>) it threw an error, but skipped the problem and moved on to the next line.
Result no file was created and there was no error.
I repaired my problem by updating the "on error resume next" statement to a "Try, Catch, End Try" structure
and putting in a check for the existence of the default output PDFfolder.
My updated "Drawings_to_PDF" app now works with the 2013 Inventor Viewer ocx. as it should
