Problems with iProperties applied by iLogic to Parts starting out of an Assembly.
stigler
stigler
.....it is not possible to create an answer in this board!!!
Hi there! It's my mistake - I wrote it in German!
Hello! I'll bring this post up again - I'm already despairing!
I want to create custom iProperties with value " " (no entry) from an assembly in all parts of the assembly.
"Increased penalties": If the iProperty already exists, the value should NOT be overwritten! I made this entry for an iProperty ("ZZZZ") as a test - works as desired with the following "external rule" named:
"Erstelle iProperties für Bauteile einer Baugruppe"
Dim odrawdoc As Document
odrawdoc = ThisApplication.ActiveDocument
customPropertySet = odrawdoc.PropertySets.Item("Inventor User Defined Properties")
Try
    oTest = customPropertySet.Item("ZZZZ")
Catch
    customPropertySet.Add("", "ZZZZ")
End Try
But now I'm failing to apply this rule to all components of an assembly via the "snippet" specified by ssyXENBT in the article linked above! The iProperty is only ever created in the assembly!
How do I get Inventor to actually provide the iProperty to the components identified via the "snippet"? Are these two rules "not" compatible?
I have found other rules in the forum, but unfortunately they ignore the existence of "valued" iProperties and then overwrite their values.
Many thanks for your help
JelteDeJong
you have to loop over all the documents referenced by the assembly. You can do that like this:
Dim doc As AssemblyDocument = ThisDoc.Document
For Each refDoc As Document In doc.AllReferencedDocuments
    Dim customPropertySet = refDoc.PropertySets.Item("Inventor User Defined Properties")
    Try
        Dim test = customPropertySet.Item("ZZZZ")
    Catch
    End Try
Next
Jelte de Jong
Blog: hjalte.nl - github.com
stigler
Hello JelteDeJong!
Thank You for your answer! It works!!
Have a nice week,
stigler
