Ilogic rule to open "change Component" dialogue box of a specific Ipart within an assembly
Tim.PelvanRijnsoever
Message 1 of 8
Hi all,
I am trying to come up with an Ilogic Rule to automatically open the "change Component" dialogue box of a specific Ipart within an assembly. i have a rule i have adapted from another forum thread here but this one requires the user to click (pick) the ipart within the assembly for the dialogue box to open after running the rule.
could someone please help me adjust this code to achieve this?
the ipart name is "Reducer BW: 1"
cheers
Tim P
Dim asm As AssemblyDocument = ThisDoc.Document
Dim occ As ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "SELECT REDUCER")
Dim occNode As BrowserNode = asm.BrowserPanes.ActivePane.GetBrowserNodeFromObject(occ)
Dim tabNode As BrowserNode = occNode.BrowserNodes(1)
tabNode.DoSelect()
ThisApplication.CommandManager.ControlDefinitions("AssemblyChangeComponentCmd").Execute
Replies (7)
Message 2 of 8
Andrii_Humeniuk
Hi @Tim.PelvanRijnsoever . Try this code:
Dim occ As ComponentOccurrence = asm.ComponentDefinition.Occurrences.ItemByName("Reducer BW:1")
occNode.DoSelect()
ThisApplication.CommandManager.ControlDefinitions("AssemblyChangeComponentCmd").Execute()
 In line 2, you need to write the name of your component ("Reducer BW:1").
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Message 3 of 8
Thanks for the reply @Andrii_Humeniuk,
when I run this rule it only selects/highlights the component in the assembly tree and doesn't open the "change Component" dialogue box..
any ideas?
Tim
Message 4 of 8
Andrii_Humeniuk
This code will definitely work:
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oPane As BrowserPane = oDoc.BrowserPanes.ActivePane
Dim oOcc As ComponentOccurrence = oDoc.ComponentDefinition.Occurrences.ItemByName("Reducer BW:1")
Dim oNode As BrowserNode = oPane.GetBrowserNodeFromObject(oOcc)
oNode.Expanded = True
Dim oTableNode As BrowserNode = oNode.BrowserNodes.Item(1)
oTableNode.DoSelect
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyChangeComponentCmd").Execute
Message 5 of 8
Thanks again @Andrii_Humeniuk,
This code works when i directly run the rule.
one small problem i didnt mention though. I am tying to use this rule in a local Form within the assembly, when i add the rule and set the Behavior of rule to "Close and Then Run Rule" under "On Click Action" it only highlights the Table of the iPart and never opens the Change Component dialogue box.
im not sure if this is a form or rule issue?
i have created a separate Rule (iLogicVB.RunRule)  to run the Change Component Rule but it still wont work.
Any thoughts?
Tim
Message 6 of 8
Hey,
just wondering if you or others could still help me with this?
cheers
Tim
Message 7 of 8
WCrihfield
Is the iLogic Form internal, or global?  Is the iLogic rule internal or external?  If the form is global, then you will need to use the 'On Click Action' that includes 'Apply' before running the rule, because changes in the form need to be 'sent' to the document first.  Also, is the form shown 'Modal' or Non-Modal?  Is the form being launched from an iLogic rule?  If so, does that rule contain more lines of code after the line of code that launches the form?
Wesley Crihfield
(Not an Autodesk Employee)
Message 8 of 8
Hi @WCrihfield,
I changed the Behavior "Modal" to True and this worked! I didn't know this was an option..
thanks for your help!
Tim PvR
