Problems augmenting thread/hole callouts with ThreadInfo object
Message 1 of 1
I'm trying to augment thread/hole callouts programatically and I've run up against a couple issues. Running the "test" script in the attached .dwg should add the major diameter to each callout where applicable.
One of the issues involves hole callouts without threading. This may simply be my inexperience with VBA and trying to test for the existence of members in objects.
The second issue is a little stranger. The top left-most callout should have a ThreadInfo object associated with it, but apparently does not.
Here is the content of the script attached in the local iLogic rules:
Public Sub Main()
  Dim invDWG As Document
  Dim invHoleThreadNote As Object
  Dim threadInfo As ThreadInfo
  invDWG = ThisApplication.ActiveDocument
  For i = 1 To invDWG.ActiveSheet.DrawingNotes.HoleThreadNotes.Count
    Do
      invHoleThreadNote = invDWG.ActiveSheet.DrawingNotes.HoleThreadNotes(i)
      On Error GoTo ThreadInfoAbsent
      Select Case invHoleThreadNote.Edge.Type
      Case = "117473792" ' axial/DrawingCurve obj
        threadInfo = invHoleThreadNote.Edge.ModelGeometry.ThreadInfos(1)
      Case = "117474048" ' profile/'Edge' obj
        threadInfo = invHoleThreadNote.Edge.Geometry.ModelGeometry.ThreadInfos(1)
      Case Else
        ThreadInfoAbsent :
        Resume Here
        Here :
        Exit Do
      End Select
      invHoleThreadNote.Text.FormattedText = invHoleThreadNote.Text.FormattedText & vbCrLf & threadInfo.MinorDiameterMax
    Loop While False
  Next i
End Sub
Any help would be much appreciated.
Replies (0)
