10:17 PM
We have some Problems with the running order of iLogic Rules.
I try to describe it in an Example, you can find attached. (The description (PDF) and the ipt-file)
Maybe someone has a solution for it?
Best Regards
Passi
PS: We're using iLogic via Addin in Inventor 2010. But I also tried it, with the 2012 version (the same problem).
PPS: The attached IPT File is running in the correct order.
