Problem with the running order of iLogic Rules.
We have some Problems with the running order of iLogic Rules.
I try to describe it in an Example, you can find attached. (The description (PDF) and the ipt-file)
Maybe someone has a solution for it?
Best Regards
Passi
PS: We're using iLogic via Addin in Inventor 2010. But I also tried it, with the 2012 version (the same problem).
PPS: The attached IPT File is running in the correct order.
Have you tried setting the 'Don't run automatically' flag in the options tab in your rule ?
This stops the rule from running if any parameters change that it references.
and thanks for the answer. It explains not the reason for this strange behaviour, but it solved the problem 🙂 and that's the most important thing.
THANK YOU
And best Regards
Passi
