Problem when replace but keep position of occurence
SandmanINV
SandmanINV
Hi Everyone,
I have a problem when I code to replace the occurrence automatically.
I have a panel A (a single part file) like the left picture. It is an occurrence in the assembly.
And a panel is panel B (an assembly file) like the right picture. The size of B is bigger than A a little.
My workflow is:
I find the occurrence A and replace it by the B.
The problem is, after replacing, the panel B does not keep the position like the panel A. They have different origin and center of mass, so I don't have the right solution to map position between them.
Could you give me an advice ?
bhavik4244
@SandmanINV
Have you used the manage function for that?
Bhavik Suthar
SandmanINV
Thank you very much, I will try follow your instruction.
