Problem to catch the Point from the Edge
o_basguener
o_basguener
Hey Guys,
I have a Problem with measuring the lid in height. I can't catch the Point1 from the Edge. I want to measure from Point1 to Edge3. I also tried with Edge1 or end of point from Edge1.
I put picures in attachment and copied the code.
I hope someone can help me.
Thank you.
oCompOcc2 = oAssDoc.ComponentDefinition.Occurrences.ItemByName("Lid")
oPartDoc2 = oCompOcc2.Definition.Document
myNamedEntities2 = iLogicVb.Automation.GetNamedEntities(oPartDoc2)
oEdge1 = myNamedEntities2.FindEntity("Edge1")
Call oCompOcc2.CreateGeometryProxy(oEdge1, oEdge1Proxy)
myCurveCandidates = oFrontView.DrawingCurves(Proxy of Edge3)
myDrawingCurve1 = myCurveCandidates.Item(1)
oGeoIntent1 = oSheet.CreateGeometryIntent(myDrawingCurve1)
myCurveCandidates = oFrontView.DrawingCurves(oEdge1Proxy)
myDrawingCurve2 = myCurveCandidates.Item(1)
oGeoIntent2 = oSheet.CreateGeometryIntent(myDrawingCurve2)
myPos2d = oTG.CreatePoint2d(myDrawingCurve1.StartPoint.X +1,oFrontView.Top-6)
oSheet.DrawingDimensions.GeneralDimensions.AddLinear(myPos2d, oGeoIntent1, oGeoIntent2)
A.Acheson
Hi @o_basguener
I'm not sure where tour retrieving rhe drawi g curve from. This doesn't seem right.
Something like this should work
' Finds the drawing edge that represents the one with the named entity.
			Try
				drawViewCurves = oFrontView.DrawingCurves(oEdge1Proxy)
			Catch
				Logger.Info("Error getting DrawViewCurves")
			End Try
			Try
				drawCurve = drawViewCurves.Item(1)
			Catch
				Logger.Info("Error getting DrawViewCurve")
			End Try
Assuming your getting the correct point on each of the intents you should set the type of dimesion required.
DimensionTypeEnum.kVerticalDimensionType
Syntax
GeneralDimensions.AddLinearTextOrigin As Point2dIntentOne As GeometryIntent, [IntentTwo] As Variant, [DimensionType] As DimensionTypeEnum, [ArrowheadsInside] As Boolean, [DimensionStyle] As Variant, [Layer] As Variant ) As LinearGeneralDimension
Regards
Alan
o_basguener
Hi @A.Acheson ,
Thank you for reply.
I tried to put in oGeoInten2 behind myDrawingCurve2  the value from PointIntentEnum with kEndPointIntent.
oGeoIntent2 = oSheet.CreateGeometryIntent(myDrawingCurve2 , PointIntentEnum.kEndPointIntent )
That was the solution. Thank you.
