Problem modifying a sub-assembly with ilogic
nicolas.oeillet
nicolas.oeillet
I have been modifying sub-assembly with iLogic for some time without any problem, but today I am faced with a problem.
I have an assembly in which there is a sub-assembly named "PB_Ens_Boit_Ressort.iam".
For example in a rule I have an error on this line: Parameter("PB_Ens_Boit_Ressort", "GAMME") = GAMME
I want to specify that it was working correctly until last week (before update to Inventor 2023.3).
In this sub-assembly, I also have a ipt named "Boitier_Ressorts" and I have this error if I changed the parameter "GAMME" manually
But the line 49194 still exist so I don't understand why there is this error.
Thanks for your help
nicolas.oeillet
That's the error about the line : Parameter("PB_Ens_Boit_Ressort", "GAMME") = GAMME
