Message 1 of 1
Placing iFeature with Ilogic (Planes and Points) (Solids)
I cannot seem to figure out placing iFeatures with iLogic, I have rewritten and changed this code a number of times but still absolutely no progress, as well I cant see anything about selecting multiple solid bodies and including that in the ifeature input. Heres the code below:
Public Sub Main() Dim oPartDoc As PartDocument oPartDoc = ThisApplication.ActiveDocument Dim oPartDef As PartComponentDefinition oPartDef = oPartDoc.ComponentDefinition 'Dim oSketch As PlanarSketch = oPartDef.Sketches.Item("Placement 2") 'Dim oPoint As SketchPoint = oSketch.SketchPoints.Item(1) 'Dim oPlane As WorkPlane = oPartDef.WorkPlanes.Item("Placement 1") Dim oFace1 As Face Dim oFace2 As Face Dim oPoint As SketchPoint oPoint = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchPointFilter, "Select Select Point") oFace1 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Face of CAM Connector Hole") oFace2 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Connecting Plane") Dim oFeatures As PartFeatures oFeatures = oPartDef.Features ' Create an iFeatureDefinition object. Dim oiFeatureDef As iFeatureDefinition oiFeatureDef = oFeatures.iFeatures.CreateiFeatureDefinition("C:\CAM CONNECTOR.ide") ' Set the input. Dim oInput As iFeatureInput For Each oInput In oiFeatureDef.iFeatureInputs Select Case oInput.Name Case "Point" Dim oPoint1Input As iFeatureEntityInput oPoint1Input = oInput oPoint1Input.Entity = oPoint Case "Face" Dim oPlane1Input As iFeatureWorkPlaneInput oPlane1Input = oInput oPlane1Input.PlaneInput = oFace1 Case "Plane" Dim oPlane2Input As iFeatureWorkPlaneInput oPlane2Input = oInput oPlane2Input.PlaneInput = oFace2 End Select Next 'Create the iFeature. Dim oiFeature As iFeature oiFeature = oFeatures.iFeatures.Add(oiFeatureDef) End Sub
I have also included the CAM connector im trying to use, maybe something about how theyre created dramatically effects how the code works? See also the image below for the kind of situation, first the point in the middle would be clicked, then the flat plane and then the vertical plane.
