Print with Macro Printer Presets
I wrote a macro about 6 months ago that allowed us to batch print and the macro chose the correct paper size and printed to it. Now we have just made our printers better and the naming convention of the paper sizes changed. The problem is that the paper size names went from 11x17 to 11" x 17". The addition of the spaces and the " is what is causing problems with the macro. If there is anyway I can get the macro to recognize the new names or recognize printer presets then I would be good to go. Here is the line of code I've used to designate paper size in the past.
oPrintMgr.PaperSize = kPaperSize11x17
Thank you for any help you can give.
Steve
skyngu
i dont think they are related. can you show us more codes?
Autodesk Inventor Professional 2019
Here is the bulk of the printing part of the code. I can get the code to print to all paper sizes that do not have a " mark or a space. I am trying to get IT to fix this but in the mean time I would like a way to deal with the " and the spaces in the paper size names.
            Dim oPrintMgr As PrintManager
            Set oPrintMgr = ThisApplication.ActiveDocument.PrintManager
            Dim oDrgPrintMgr As DrawingPrintManager
            Set oDrawDoc = ThisApplication.ActiveDocument
            Set oDrgPrintMgr = oDrawDoc.PrintManager
            oDrgPrintMgr.AllColorsAsBlack = True
            oDrgPrintMgr.ScaleMode = kPrintBestFitScale
            ' Printer setup, default printer
            printingprinter = printer
            oPrintMgr.Printer = printingprinter
            oPrintMgr.ColorMode = kPrintDefaultColorMode ' Set to default
            oPrintMgr.NumberOfCopies = 1 ' Set to print one copies.
            oPrintMgr.Orientation = kLandscapeOrientation ' Set to print using landscape orientation.
            oPrintMgr.SubmitPrint ' Submit the print.
