PRINT TO PDF AND EXPORT TO DWG
buitrongcuongypbn2000
Hi everyone!
I need to have the code in Ilogic or another way to print all drawings I want to PDF file quicker.
Besides, I also need the code to export all drawings I want to DWG.
If you have any solutions, let's feedback in this post.
Thanks for your attention!
Frederick_Law
You'll need ini file with DWG export setting.
VBA Macro:
Sub SplitPath(Fullname As String, Path As String, Filename As String)
    Dim PathLength As Integer
    Dim PathEnd As Integer
    Dim i As Integer
    i = 1
    PathLength = Len(Fullname)
    While i <= PathLength
      If Mid(Fullname, i, 1) = "\" Then
        PathEnd = i
      End If
      i = i + 1
    Wend
    Path = Left(Fullname, PathEnd)
    Filename = Mid(Fullname, PathEnd + 1, PathLength - PathEnd - 4)
End Sub
Public Sub PublishPDF()
    ' Get the PDF translator Add-In.
    Dim PDFAddIn As TranslatorAddIn
    Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
    'Set a reference to the active document (the document to be published).
    Dim oDocument As Document
    Set oDocument = ThisApplication.ActiveDocument
    Dim oContext As TranslationContext
    Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = kFileBrowseIOMechanism
    ' Create a NameValueMap object
    Dim oOptions As NameValueMap
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    ' Create a DataMedium object
    Dim oDataMedium As DataMedium
    Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
    ' Check whether the translator has 'SaveCopyAs' options
    If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        ' Options for drawings...
        oOptions.value("All_Color_AS_Black") = 0
        oOptions.value("Remove_Line_Weights") = 0
        ' Resolutions: 150, 200, 300, 400, 600, 720, 1200, 2400, 4800
        oOptions.value("Vector_Resolution") = 1200
        oOptions.value("Sheet_Range") = kPrintAllSheets
        'oOptions.Value("Custom_Begin_Sheet") = 2
        'oOptions.Value("Custom_End_Sheet") = 4
    End If
    Dim DrawingName As String
    DrawingName = " "
    Dim DrawingPath As String
    DrawingPath = " "
    Dim DrawingFullName As String
    DrawingFullName = oDocument.FullFileName
    Call SplitPath(DrawingFullName, DrawingPath, DrawingName)
    'Check if folder exist, create if not
    On Error Resume Next
    Dim fs, f
    Set fs = CreateObject("Scripting.FileSystemObject")
    Set f = fs.CreateFolder(DrawingPath + "PDF")
    'Set the destination file name
    oDataMedium.Filename = DrawingPath + "PDF\" + DrawingName + ".pdf"
    'Publish document.
    Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
Public Sub PublishDWG()
    ' Get the DWG translator Add-In.
    Dim DWGAddIn As TranslatorAddIn
    Set DWGAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}")
    If DWGAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        Dim strIniFile As String
        strIniFile = "C:\DWGOut.ini"
        ' Create the name-value that specifies the ini file to use.
        oOptions.value("Export_Acad_IniFile") = strIniFile
    End If
    DrawingName = " "
    DrawingPath = " "
    Dim fs, f
    Set f = fs.CreateFolder(DrawingPath + "DWG")
    oDataMedium.Filename = DrawingPath + "DWG\" + DrawingName + ".dwg"
    'Publish document.
    Call DWGAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
Public Sub Publish_All_IDW()
Dim fs, f
Dim oDoc As Document
Dim oApp As Inventor.Application
Dim IDWFile As String
Set oApp = ThisApplication
DrawingName = " "
DrawingPath = " "
DrawingFullName = SelectFileDialog(4)
If DrawingFullName <> "" Then
  ChDir (DrawingPath)
  Debug.Print DrawingPath
  IDWFile = Dir(DrawingPath + "\*.IDW")
  While IDWFile <> ""
    Debug.Print IDWFile
    Set oDoc = oApp.Documents.Open(DrawingPath + "\" + IDWFile)
    PublishPDF
    PublishDWG
    oDoc.Close
    IDWFile = Dir
  Wend
End If
End Sub
Frederick_Law
Here is addin for the same thing.
Extract the folder to: %AppData%\Autodesk\ApplicationPlugins
It'll add 3 icons to ribbon.
Open a idw, the addin will export all idw in the same folder.
Thanks for your support!
But I can not active this tool.
Could you post the video guidance for me?
Thank you very much!
Frederick_Law
Which one you cannot activate?
What have you done already?
If the addin is in correct folder, enable it here:
I have succeeded with your tool. But I still have a new problem.
I need to add a template file AutoCAD here.
Do you have anyway?
Best regard,
Frederick_Law
Sorry I don't.  I just export idw with Border and Titleblock.
You can edit the VBA marco to include Template.
