Print Drawing Depending on Sheetsize
Jesper_S
Jesper_S
Hi.
I'm trying to create a iLogic code that prints my drawings and depending on what the sheetsize is, it sends it to diffrent printers (A4 & A3 same printer, A2 & A1 diffrent printer) and adjusts the printmanagers sheetsize.
Found a post regarding this but can't get it to work.
https://forums.autodesk.com/t5/inventor-customization/ilogic-print-to-active-sheet-size/td-p/5816292
I get the error "Can't convert the String A3 to Integer"
Here is my attempt.
Sub Main()
Dim oDrgDoc As DrawingDocument
oDrgDoc = ThisApplication.ActiveDocument
' Set reference to drawing print manager' DrawingPrintManager has more options than PrintManager' as it's specific to drawing document
Dim oDrgPrintMgr As DrawingPrintManager
oDrgPrintMgr = oDrgDoc.PrintManager
Dim PrinterPlotter = "\\OVO-PRINT01\OVB-HQ-Floor1-Construction-Plotter-01"
Dim PrinterCommon = "\\OVO-PRINT01\OVB-HQ-Floor1-Common-Color-01"
'MessageBox.Show(GetPaperSize(ActiveSheet.Size), "Title")
SheetSize = ActiveSheet.Size
MessageBox.Show(SheetSize, "Title")
If SheetSize = "A4" Then
	oDrgPrintMgr.Printer = PrinterCommon
ElseIf SheetSize = "A3" Then
ElseIf SheetSize = "A2" Then
	oDrgPrintMgr.Printer = PrinterPlotter
ElseIf SheetSize = "A1" Then
' Set the printer name' comment this line to use default printer or assign another one
'oDrgPrintMgr.Printer = PrinterCommon
'Set the paper size , scale and orientation
oDrgPrintMgr.ScaleMode = PrintScaleModeEnum.kPrintBestFitScale
'oDrgPrintMgr.PaperSize = PaperSizeEnum.kPaperSizeA3
oDrgPrintMgr.PaperSize = GetPaperSize(ActiveSheet.Size)
oDrgPrintMgr.PrintRange = kPrintAllSheets
oDrgPrintMgr.Orientation = kLandscapeOrientation
oDrgPrintMgr.AllColorsAsBlack = True
oDrgPrintMgr.SubmitPrint
End Sub
Function GetPaperSize(shtSize As DrawingSheetSizeEnum) As PaperSizeEnum
    'Add a line for each sheet and papersize combination
    If shtSize = DrawingSheetSizeEnum.kA0DrawingSheetSize Then Return PaperSizeEnum.kPaperSizeA0
End Function
Thanks in advance
//Jesper
JhoelForshav
Hi @Jesper_S
Sheet.Size is of type DrawingSheetSizeEnum (Integer), not String.
Instead of
If SheetSize = "A4"
It should be
If SheetSize = DrawingSheetSizeEnum.kA4DrawingSheetSize
And so on for all the different sizes 🙂
Jesper_S
Hi.
Thanks for your answer.
But I think that it's the Function that's the issue and the Calling Out for the sheetsize.
If I comment this out and use
it works.
The first section of "If" is to select the correct printer.
If it's A4 & A3, select the common printer.
If it's A2 & A1, select the plotter.
//Jesper
JhoelForshav
I see now that you used
ActiveSheet.Size
which in fact is a string...
ActiveSheet is of type ICadDrawingSheet and Not Sheet.
Your function GetPaperSize however takes an argument of type DrawingSheetSizeEnum but you call it with argument ActiveSheet.Size which is a string.
Try changing
To
oDrgPrintMgr.PaperSize = GetPaperSize(ActiveSheet.Sheet.Size)
JhoelForshav
And the function like this i suppose? 🙂
	If shtSize = DrawingSheetSizeEnum.kA1DrawingSheetSize Then Return PaperSizeEnum.kPaperSizeA1
	If shtSize = DrawingSheetSizeEnum.kA2DrawingSheetSize Then Return PaperSizeEnum.kPaperSizeA2
	If shtSize = DrawingSheetSizeEnum.kA3DrawingSheetSize Then Return PaperSizeEnum.kPaperSizeA3
	If shtSize = DrawingSheetSizeEnum.kA4DrawingSheetSize Then Return PaperSizeEnum.kPaperSizeA4
End Function
Jesper_S
Sweet, Thanks.
Worked like  charm.
Only problem I got now is that the Plotter Printer has crashed so I can't test the code on that one....
Our IT is trying to fix it, software issue...
But i think that the code will do the job.
Thanks once again.
EDIT: Yes the function should look like that.. have changed it, saw your reply after I posted.
//Jesper
