Colour Face Of A-Side In Specific ViewRep C#
bruce.blundell
bruce.blundell
Hi All,
I am looking to Set the color of the A-Side face to a specific color
but only do it in a specific view rep
my code is in C# but happy to translate from Vb
I am able to set the view rep no problem
 public void PrtCreateVRep(string nViewRep)
            Connect(out Inventor.Application m_InvApp, out bool InvActive);
            TestPart(out bool oPartTest);
            if (oPartTest == true)
                //Active Part Document
                PartDocument oPartDoc = (PartDocument)m_InvApp.ActiveDocument;
                //Define Component definition
                PartComponentDefinition oCompDef = oPartDoc.ComponentDefinition;
                //get Manager of Representations
                RepresentationsManager dViewRepMgr = oCompDef.RepresentationsManager;
                //get active Representation view
                DesignViewRepresentation dViewRep = dViewRepMgr.ActiveDesignViewRepresentation;
                DesignViewRepresentations oDesignViewReps = oCompDef.RepresentationsManager.DesignViewRepresentations;
                //DesignViewRepresentation oDesignViewRep = default(DesignViewRepresentation);
                int dViewRepCounts = oDesignViewReps.Count;
                if (nViewRep != "")
                    try
                        oDesignViewReps[nViewRep].Activate();
                        //Inventor Status Bar Feedback
                        m_InvApp.StatusBarText = "View Representation: " + "'" + nViewRep + "'" + " Exists. " + "'" + nViewRep + "'" + " View Representation Now Activaded.";
                    catch
                        oDesignViewRep = oDesignViewReps.Add(nViewRep);
                        m_InvApp.StatusBarText = "View Representation: " + "'" + nViewRep + "'" + " Created. " + "'" + nViewRep + "'" + " View Representation Now Activaded.";
                else
                    MessageBox.Show("No View Rep Name Selected!", "UAPTools");
            else
                MessageBox.Show("Please Activate a Valid Part Document", "UAPTools");
Then set the face to the Color
 public void SetA_SideColour(string oColour)
            Connect(out Inventor.Application m_InvApp);
            InvPart constrClass = new InvPart();
            constrClass.TestPart(out bool oPartTest);
                //PartComponentDefinition oCompDef = oPartDoc.ComponentDefinition;
                SMCheck(out bool oSMTest);
                if (oSMTest == true)
                    SheetMetalComponentDefinition oSMCompDef = (SheetMetalComponentDefinition)oPartDoc.ComponentDefinition;
                    if (oSMCompDef.ASideFaceStatus == ASideFaceStatusEnum.kASideUpToDate)
                        ASideDefinition oAsideDef = oSMCompDef.ASideDefinitions[1];
                        Face oFace = oAsideDef.Faces[1];
                        //Face oFace = oAside.Faces[1];
                        if (oColour != "")
                            if (oColour == "As Feature")
                                try
                                    //Set Enum
                                    StyleSourceTypeEnum oStyle = StyleSourceTypeEnum.kFeatureRenderStyle;
                                    //Set Render Style of faces
                                    oFace.SetRenderStyle(oStyle);
                                catch
                                    m_InvApp.StatusBarText = "RenderStyle/Appearance : " + "' " + oColour + " '" + " Could Not Be activated";
                            else
                                try
                                    RenderStyle oRenderStyle = oPartDoc.RenderStyles[oColour];
                                    //Set Enum
                                    StyleSourceTypeEnum oStyle = StyleSourceTypeEnum.kOverrideRenderStyle;
                                    oFace.SetRenderStyle(oStyle, oRenderStyle);
                                catch
                    else
                    m_InvApp.ActiveView.Update();
But This overrides the color in all view reps
Any thoughts?
bruce.blundell
@NachoShaw  any ideas?
JMGunnar
Designviews in Parts not support different Face colour
Inventor Ideas
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
NachoShaw
We could add a condition based on a view rep and call the function on a documentEvent. The color, face name & viewrep name could be saved as attributes along with the face name
Change ViewRep
initiate DocumentEvent
check thata ViewRep has changed and get its name
If ViewRep Name = Attribute ViewRep name
Select face by Attribute name
assign Attribute color to it
you can save attributes to a face so each face can hold its own attribute colors and then be collected when the face is selected
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
