Hi all,
I am struggling with reference keys in inventor. I boiled it down to a simple (reproduzible) procedure:
1) Get a selected Edge and unselect it
2) Get the reference key and context key of this edge
3) Print generated keys as string
4) Act is if i loaded those from a file and create a new context from the context key
5) Trace the reference key with the new context back to the edge and select it
I wrote the program in C# and VBA. You can see both programms below. In VBA it works fine, in C# it breaks. When analyzing the generated keys one can see that the generated context keys are very different. Much shorter for the C# program. When I am loading the VBA strings in C# the program runs without problems. So the problem is that the context key as byte array is wrong in C#.
Is there a bug in the program? Does somebody know a workaround in C# maybe? Can I call one line of VBA from C#?
Thanks for every idea!
Output of context and reference strings:
Keys printed by C#:
AgAAAAEAAAA=
AgECACgAAAACAQEACAAAAC0AAAADAAAAAQQBABAAAAAAAAAAAgAAAAQAAAAGAAAA
Keys printed by VBA:
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
C#-Code:
// Get the active document and a selected edge
var assemblyDocument = (AssemblyDocument)_invAPI.getActiveDocument(_invAPI.InvApp);
var selectSetEnumerator = assemblyDocument.SelectSet.GetEnumerator();
selectSetEnumerator.MoveNext();
var currentEdgeProxy = (EdgeProxy)selectSetEnumerator.Current;
// Clear selection
assemblyDocument.SelectSet.Clear();
// Get keys of reference and context
var keyManager = assemblyDocument.ReferenceKeyManager;
int context = keyManager.CreateKeyContext();
byte[] contextBytes = new byte[1];
keyManager.SaveContextToArray(context, ref contextBytes);
byte[] referenceBytes = new byte[1];
currentEdgeProxy.GetReferenceKey(ref referenceBytes, context);
// Act as if i saved and loaded the keys
Debug.WriteLine(keyManager.KeyToString(contextBytes));
Debug.WriteLine(keyManager.KeyToString(referenceBytes));
// Load new context from context key - WITHOUT THIS LINE IT WORKS IN C#
context = keyManager.LoadContextFromArray(ref contextBytes);
// Find new edge from reference key with new context - FAILS IN C#
object entity = keyManager.BindKeyToObject(ref referenceBytes, context, out object MatchType);
assemblyDocument.SelectSet.Select(entity);
VBA-Code:
Public Sub TestReferenceKey()
' Get the active document and a selected edge
Dim assemblyDocument As Document
Set assemblyDocument = ThisApplication.ActiveDocument
Dim edgeProxy As edgeProxy
Set edgeProxy = assemblyDocument.SelectSet.Item(1)
' Clear selection
' Get key manager and create a new context
Dim keyManager As ReferenceKeyManager
Set keyManager = assemblyDocument.ReferenceKeyManager
Dim context As Long
' Get keys of reference and context
Dim referenceBytes() As Byte
Call edgeProxy.GetReferenceKey(referenceBytes, context)
Dim contextBytes() As Byte
Call keyManager.SaveContextToArray(context, contextBytes)
' Act as if i saved and loaded the keys
Debug.Print keyManager.KeyToString(contextBytes)
Debug.Print keyManager.KeyToString(referenceBytes)
' Load new context from context key
context = keyManager.LoadContextFromArray(contextBytes)
' Find new edge from reference key with new context
Dim foundEdge As Edge
Set foundEdge = keyManager.BindKeyToObject(referenceBytes, context)
' Select edge again
assemblyDocument.SelectSet.Select foundEdge
End Sub
PS:
Edit 1: Added print of context and reference keys as string and the resulting strings
Edit 2: Rewrite with the problem being the context key generation
