Potential Bug in C#-Api: Different behavior in generating context key as bytes array (SaveContextToArray)
PanWauu
PanWauu
Hi all,
I am struggling with reference keys in inventor. I boiled it down to a simple (reproduzible) procedure:
1) Get a selected Edge and unselect it
2) Get the reference key and context key of this edge
3) Print generated keys as string
4) Act is if i loaded those from a file and create a new context from the context key
5) Trace the reference key with the new context back to the edge and select it
I wrote the program in C# and VBA. You can see both programms below.  In VBA it works fine, in C# it breaks. When analyzing the generated keys one can see that the generated context keys are very different. Much shorter for the C# program. When I am loading the VBA strings in C# the program runs without problems. So the problem is that the context key as byte array is wrong in C#.
Is there a bug in the program? Does somebody know a workaround in C# maybe? Can I call one line of VBA from C#?
Thanks for every idea!
Output of context and reference strings:
Keys printed by C#:
AgAAAAEAAAA=
AgECACgAAAACAQEACAAAAC0AAAADAAAAAQQBABAAAAAAAAAAAgAAAAQAAAAGAAAA
Keys printed by VBA:
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
C#-Code:
// Get the active document and a selected edge
var assemblyDocument = (AssemblyDocument)_invAPI.getActiveDocument(_invAPI.InvApp);
var selectSetEnumerator = assemblyDocument.SelectSet.GetEnumerator();
selectSetEnumerator.MoveNext();
var currentEdgeProxy = (EdgeProxy)selectSetEnumerator.Current;
// Clear selection
assemblyDocument.SelectSet.Clear();
// Get keys of reference and context
var keyManager = assemblyDocument.ReferenceKeyManager;
int context = keyManager.CreateKeyContext();
byte[] contextBytes = new byte[1];
keyManager.SaveContextToArray(context, ref contextBytes);
byte[] referenceBytes = new byte[1];
currentEdgeProxy.GetReferenceKey(ref referenceBytes, context);
// Act as if i saved and loaded the keys
Debug.WriteLine(keyManager.KeyToString(contextBytes));
Debug.WriteLine(keyManager.KeyToString(referenceBytes));
//  Load new context from context key - WITHOUT THIS LINE IT WORKS IN C#
context = keyManager.LoadContextFromArray(ref contextBytes);
// Find new edge from reference key with new context - FAILS IN C#
object entity = keyManager.BindKeyToObject(ref referenceBytes, context, out object MatchType);
assemblyDocument.SelectSet.Select(entity);
VBA-Code:
Public Sub TestReferenceKey()
    ' Get the active document and a selected edge
    Dim assemblyDocument As Document
    Set assemblyDocument = ThisApplication.ActiveDocument
    Dim edgeProxy As edgeProxy
    Set edgeProxy = assemblyDocument.SelectSet.Item(1)
    ' Clear selection
    ' Get key manager and create a new context
    Dim keyManager As ReferenceKeyManager
    Set keyManager = assemblyDocument.ReferenceKeyManager
    Dim context As Long
    ' Get keys of reference and context
    Dim referenceBytes() As Byte
    Call edgeProxy.GetReferenceKey(referenceBytes, context)
    Dim contextBytes() As Byte
    Call keyManager.SaveContextToArray(context, contextBytes)
    ' Act as if i saved and loaded the keys
    Debug.Print keyManager.KeyToString(contextBytes)
    Debug.Print keyManager.KeyToString(referenceBytes)
    ' Load new context from context key
    context = keyManager.LoadContextFromArray(contextBytes)
    ' Find new edge from reference key with new context
    Dim foundEdge As Edge
    Set foundEdge = keyManager.BindKeyToObject(referenceBytes, context)
    ' Select edge again
    assemblyDocument.SelectSet.Select foundEdge
End Sub
PS:
Edit 1: Added print of context and reference keys as string and the resulting strings
Edit 2: Rewrite with the problem being the context key generation
matt_jlt
I could be wrong as i am not too familiar with C#, but maybe try to not specify the byte array length on the reference key byte arrays.
= new byte[] { };
Also, maybe define the edge as an inventor.edgeproxy object See if that helps.
PanWauu
This did not change anything in my case. The edge is already casted to EdgeProxy and the bytes are overwritten anyways.
While testing your suggestion, I also noticed that the context strings between the programms are quite different! I edited the original post to include this info.
Do you see a problem with the generation of the context?
PanWauu
BTW when adapting the code for parts (Change "AssemblyDocument" to "PartDocument" and "EdgeProxy" to "Edge") both programs also return different context keys but the C# programm still is not able to recover the edge.
I tried to use the VBA generated Keys in C# and can recover the edge there. So the problem is the context key in bytes in C#. I will edit the original question
PanWauu
I am still struggling with this issue. In short when I try to save the context to string I get different results in c# and vba. Glad for any help or also validation that this is a bug
PanWauu
I solved my problem myself now. I did not have a sufficient understanding of the reference keys. Sadly my "exactly mirrored" code examples of C# and VB contain a difference. In VB i first generate a reference key in the context and then save the context. In C# i first save the context and then generate a reference key. Apperantly the generation of reference keys does ALTER the context and because of that the order of calls does matter.
