Populate comboboxes with content center family key columns
j_chaissonQB25Y
j_chaissonQB25Y
Good afternoon everyone,
is there any one out there that knows how to populate a combobox by pointing to a family’s key column and then the next combobox narrows it down and so on. Essentially the same way content center works with listboxes but with comboboxes. I’m working on a form and would love to be able to drive and pick all my components from one form.
-Jeremy
A.Acheson
Hi @j_chaissonQB25Y
Could you explain the type of form your using? You might have a better time creating a winform explained here and then populating with the family table data. Do you have the code required for accessing the family data? If so attach here, if not there is some samples on this forum.   Could you attach an approximate sample of what you want to achieve, where your selecting the family information and hopefully someone can point you in the right direction.
Regards
Alan
j_chaissonQB25Y
I already have a form created. I’m using Visual Studio. I’m not quite sure how to reference the family keys into each combobox.
Type: is the family (Heavy Barrel, Long Weld Neck)
Class: (150,300,etc)
Joint: (RF,RTJ)
….and so on, by the time you have selected the options you have narrowed down to correct part to place or replace.
A.Acheson
Hi @j_chaissonQB25Y
Here is a method to be run in a CC part file that contains a ND column, any ANSI pipe Fitting. The function will return the current size and the sub will get all ND's.
	Sub Main
		a = GetND()
		MessageBox.Show(a, "Title")
		GetAllND()
	End Sub
	Function GetND() As String
		Dim doc As PartDocument = ThisDoc.Document
		Dim oCC As ContentCenter = ThisApplication.ContentCenter
		Dim propSet As PropertySet = doc.PropertySets.Item("{B9600981-DEE8-4547-8D7C-E525B3A1727A}")
		'Get FamilyId property.
		Dim familyId As Inventor.Property = propSet.Item("FamilyId")
		'Get Family.
		Dim oContentFamily As ContentFamily = oCC.GetContentObject("v3#" & familyId.Value & "#")
		' Get MemberId property
		Dim strMemberId As String = propSet("MemberId").Value
		'Get Current Row
		Dim oCurrentTableRow As ContentTableRow = oCC.GetContentObject("v3#" & familyId.Value & "#" & strMemberId)
		Dim NDCol As ContentTableColumn
		Dim ND As String
		'Set the column criteria.
		Try
			NDCol = oContentFamily.TableColumns.Item("ND")
			ND = oCurrentTableRow.GetCellValue(NDCol)
		Catch
		End Try
		Return ND
	End Function
	Sub GetAllND()
		Dim NDList As New List (Of String)
		'Get Family.
		'Get Current Row
		For Each oCurrentTableRow As ContentTableRow In oContentFamily.TableRows
				Dim ND As String
				Try
					NDList.Add(ND)
				Catch
				End Try
		Next
		d0 = InputListBox("Prompt", NDList, d0, Title := "Title", ListName := "List")
	End Sub
And here is how you would use change a part in the assembly with 3 variable criteria to select a member row. The criteria is all manually input so you will need to ensure your family contains this data.
'https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/change-length-of-a-content-center-file-with-ilogic/td-p/9512570
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
Dim oCCmember As ComponentOccurrence
'[Select Components
Dim comps As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
Dim comp As Object
'Set a reference to the select set of the active document.
 Dim oSelectSet As SelectSet = ThisApplication.ActiveDocument.SelectSet
If oSelectSet.Count = 0 Then ' Check to make sure items were pre selected in browser pane or windowing compoonents.
	'[Selecting Component using Pick.
	While True
		comp = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter,"Select a component to add to the folder, Press Esc when Complete")
		'If nothing gets selected then we're done.
		If IsNothing(comp) Then Exit While
			comps.Add(comp)
	End While
'Allow the user to select manually occurrences in advance of running the rule.
ElseIf oSelectSet.Count > 0 Then
	For Each comp In oSelectSet
		If TypeOf comp Is ComponentOccurrence
			comps.Add(comp)
		Else
		End If
	Next
	'[Pause Inventor between selections
	'https://ekinssolutions.com/selecting-multiple-entities-using-pick-in-inventor/
	System.Windows.Forms.Application.DoEvents()
    System.Threading.Thread.Sleep(300)
End If
Dim NDList As String() = {"2", "3", "4", "5", "6" }
Dim ND As String = InputListBox("Choose a ND", NDList, "2", Title := "Change Dia", ListName := "Dia")
If ND = Nothing Then :	MessageBox.Show("Exiting", "Title") : Return :End If
Dim SchList As String() = {"10", "40", "Current"}
Dim Sch As String = InputListBox("Choose a Sch", SchList, "Current", Title := "Change Sch", ListName := "Sch")
If Sch = Nothing Then :	MessageBox.Show("Exiting", "Title") : Return :End If
Dim MatList As String() = {"Steel, Wrought", "Aluminum", "Current" }
Dim Mat As String = InputListBox("Choose a Mat", MatList, "Current", Title := "Change Mat", ListName := "mat")
If Mat = Nothing Then :	MessageBox.Show("Exiting", "Title") : Return :End If
For Each comp In comps
	 oCCmember = comp
	Dim propSet As PropertySet = oCCmember.Definition.Document.PropertySets.Item("{B9600981-DEE8-4547-8D7C-E525B3A1727A}")
	'Get Family.
	'Get Current Row
	Dim SchCol As ContentTableColumn
	Dim MatCol As ContentTableColumn
	Dim oNewMember As String
	Dim ee As MemberManagerErrorsEnum
	Try
	Catch
	End Try
	Try
		SchCol = oContentFamily.TableColumns.Item("SN")
		If Sch = "Current" Then
			'Get current schedule or have seperate list.
			Sch = oCurrentTableRow.GetCellValue(SchCol)
		End If
	Catch
	End Try
	Try
		MatCol = oContentFamily.TableColumns.Item("MATERIAL")
		If Mat = "Current" Then
			Mat = oCurrentTableRow.GetCellValue(MatCol)
		End If
	Catch
	End Try
		'Get Row.
		For Each oContentTableRow As ContentTableRow In oContentFamily.TableRows
			If Not SchCol Is Nothing Then
				'Set the criteria for row selection
				If oContentTableRow.GetCellValue(NDCol) = ND AndAlso oContentTableRow.GetCellValue(SchCol) = Sch AndAlso oContentTableRow.GetCellValue(MatCol) = Mat Then
					Try
						oNewMember = oContentFamily.CreateMember(oContentTableRow, ee, "Some error occured", , False, )
						oCCmember.Replace(oNewMember, True)
					Catch
						Logger.Info("ERROR")
					End Try
				End If
			ElseIf SchCol Is Nothing Then
				If oContentTableRow.GetCellValue(NDCol) = ND AndAlso oContentTableRow.GetCellValue(MatCol) = Mat Then
					Try
					Catch
					End Try
				End If
		 	End If
		Next
		If  String.IsNullOrEmpty(oNewMember) Then
			MessageBox.Show("No matching row found", "Title")
		End If
		'oDoc.Update
	 oCCmember.Parent.Document.Update
Next
As for the dynamic component box population you would need to recheck each list and check it is a valid value by checking its value and its row index. Gets fairly messy.
Regards
Alan
j_chaissonQB25Y
thank you for this code it will come in handy, but im looking for a method that targets the key column for each combobox and returns a list of options in the combobox. i dont want to hard code the key options because then i need to constantly update my addin. if its referencing the key columns any changes in the CC family will automatically update in the addin.
j_chaissonQB25Y
also......... your first method that returns the ND size and then every other ND it works great but there is one flaw, how do you get it to only return unique ND's and not duplicates?
A.Acheson
Hi @j_chaissonQB25Y
The member name will be unique or if all the other variables you provide are valid then this will indicate what member row to select assuming there is enough tested to make them unique. For removing duplicates from lists you can check stack overflow or similar forums for these methods.
I am not certain if there is a key identifier for content center column.
I found this here in the api help.
Maybe you can do a search of the API Help also.
Regards
Alan
