Please Help!!! - Rotate new Workplane along a default Axis With API
jpchaisson
Message 1 of 9
jpchaisson
How do you create a new Workplane from a Defualt Plane and rotate it along a default Axis?
I am new to API and trying to create workplanes and rotate them along a Axis.
Im trying to use "AddByPlaneAndOffset" is this the right method?
Replies (8)
Message 2 of 9
Ralf_Krieg
Hi
No, AddByPlaneAndOffset allows only a plane parallel to the source plane. Use SetByLinePlaneAndAngle instead.
R. Krieg
RKW Solutions
www.rkw-solutions.com
Message 3 of 9
jpchaisson
can you show me a example of using that method?
Message 4 of 9
jpchaisson
ok i have it working, but my angle isnt coming out right. how do i set the angle as a Object?
Message 5 of 9
Ralf_Krieg
Hi
Sorry, couldn't provide the example at work. Now at home I'm too late.
The angle, if provided as numeric value without dimension is interpreted as radiant !
From developers help:
Input Variant that defines the offset angle of the work plane from the input plane. This can be a numeric value or a string. The offset angle of a work plane is always defined by a parameter. When a new work plane is created, the parameter is automatically created. If a numeric value is supplied the new parameter is set to the value specified and the value is always in radians. If a string is supplied it is used as the expression for the newly created parameter and will be interpreted the same as if the user entered it in a dialog. This means if a value is specified without a unit qualifier it will default to the current document length unit. The following is a valid entry for the angle, assuming the parameter d2 already exists and defines an angle, 'd2 + 10 deg'. The positive angle direction is computed by crossing the axis vector with the plane normal vector.
R. Krieg
RKW Solutions
Message 6 of 9
jpchaisson
thank you for responding, i think i understand what you are saying heres my code for a more visual.
Dim oPartDoc As PartDocument
Dim oPartCompDef As PartComponentDefinition
Dim BaseXY As WorkPlane
Dim AxisX As WorkAxis
Dim oANG1 As Double
           oPartDoc = oApp.ActiveDocument
        oPartCompDef = oPartDoc.ComponentDefinition
        BaseXY = oPartCompDef.WorkPlanes.Item(3)
        AxisX = oPartCompDef.WorkAxes.Item(1)
        oANG1 = "30"
        oPartCompDef.WorkPlanes.AddByLinePlaneAndAngle(AxisX, BaseXY, oANG1)
what am i doing wrong my workplane ends up being a 2.xxxxxxx deg angle???
Message 7 of 9
Ralf_Krieg
Hello
Try
Dim oANG1 As String
oANG1 = "30 grd"
Your code means an angle of 30 radiant = 1718,8733853925°.
R. Krieg
RKW Solutions
Message 8 of 9
jpchaisson
Thank you so much its working great now.
can you explain what the "grd" means ?
Message 9 of 9
Ralf_Krieg
Hi
"grd" means just grad or degrees or ° and is the unit of angle value. Take a look at your fx-Parameters after creating your workplane and the new parameter for the angle.
R. Krieg
RKW Solutions
