Please HELP! Need to change frame generator member size via iLogic
mtresky
mtresky
I am looking to change the size of a frame member using iLogic.
Being that a frame generator assembly does not appear to have a table (like most iParts/iAssemblies) I am having trouble using the "changeRow" command.  I want to be able to select the size of member based on a users desire.  Future state, is an excel spreadsheet will eventually build assemblies for us, for now I just need to figure out if I can change to a different row/member of a content center part placed using frame generator.
Any input would be appreciated.
Thanks!
chandra.shekar.g
Autodesk Support
Autodesk Support
@mtresky,
Unfortunately, there is no Inventor API for frame generator. Please log a new wish list at idea station
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
or add comment on existing wish list at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/api-for-frame-generator/idi-p/8265215
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
mtresky
OK Thank you for the reply sir.
