Placing iLogic components in an assembly
Message 1 of 1
I found some code that creates a button to place an iLogic component but you have to pick which component.
Dim controlDef as ControlDefinition = _ThisApplication.CommandManager.ControlDefinitions.Item("iLogic.PlaceComponent")controlDef.Execute
is there a way to have this code automatically select a specific file and not open the dialog box?
Also the Place iLogic component command automatically copies the part into the open assembly directory and attaches a number on the end.  Is there a way when I click the done or finish placing the iLogic component that it would do a 'Save Copy and replace' the placed iLogic component saving the part to a name using the generated part number?
I've attached the part and external rules in case you want to take a look at what I have done so far.
Replies (0)
