Placing CC Part with ilogic not working correctly
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Got an rule which is getting an number from the numberingscheme in vault. This number needs to be given to the Content Center part which the rule is placing.
Now the rule creates an part but when running the rule again in the assembly it replaces also the part which is placed in the first pattern..
Even when im using a different thickness .
Also sometimes it doesnt place the custom part in the project path but makes it an Content Center File
Im using below code.
Sub Main
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
MessageBox.Show("Only in Assembly", "Message", MessageBoxButtons.OK, MessageBoxIcon.Error)
Return
End If
PartNumber = getFilenamesFromVaultNamingScheme("Sequential 2020", "", 1)
setfile(PartNumber)
Return
End Sub
To Get the numer im using this part:
Function getFilenamesFromVaultNamingScheme(RequiredSchemeName As String, RequiredSchemeString As String, numberOfNames As Integer)
Dim Connection As VDF.Vault.Currency.Connections.Connection = edm.EdmSecurity.Instance.VaultConnection()
Dim genNum As String = String.Empty
If Not Connection Is Nothing Then
Dim entityClassId = VDF.Vault.Currency.Entities.EntityClassIds.Files
Dim numSchemes As ACW.NumSchm() = Connection.WebServiceManager.NumberingService.GetNumberingSchemes(entityClassId, Nothing) 'kanske inte nothing
Dim requiredScheme As ACW.NumSchm = (From sch As ACW.NumSchm In numSchemes
Where sch.Name = RequiredSchemeName
Select sch).FirstOrDefault()
Dim numGenArgs() As String = {RequiredSchemeString }
genNum = Connection.WebServiceManager.DocumentService.GenerateFileNumber(requiredScheme.SchmID, numGenArgs)
Return genNum
Else
MessageBox.Show("Vault didn't work", "Fail!", _
End If
End Function
And to place the part im using this part:
Public Sub setfile(partnum As String)
Components.ContentCenterLanguage = "en-US"
Dim lWelds As Double
lWelds = InputBox("Geef aantal langsnaden op?", "Aantal Langsnaded", "1")
Dim Thickness As Double
Thickness = InputBox("Geef plaat dikte op", "Plaat Dikte", "6")
Dim Path As String = ThisDoc.Path
Dim oCCPart As ManagedComponentOccurrence
'Dim oCCPartName As String = "Start/Finish Plate " & Thickness & "mm (" & partnum & ".ipt"
Dim oCCPartName As String = partnum & ".ipt"
MessageBox.Show(oCCPartName, "Title")
oCCPart = Components.AddContentCenterPart(oCCPartName,
"PARTS:FIB SHELL SECTIONS",
"Start Finish Plate (2x per LW)", '''place your profile here
"20056248", ''' place initial component parameters here
position := Nothing, grounded := True, visible := False, appearance := Nothing)
testing = "Start/Finish Plate " & Thickness & "mm"
Patterns.AddRectangular(testing, oCCPartName, lWelds, 0.2 mm, Nothing, "X Axis", columnNaturalDirection := True, rowCount := 2, rowOffset := 2 mm, rowEntityName := "Y Axis", rowNaturalDirection := True)
Dim FE As String = partnum & ".ipt" '''file name
Dim PFE As String = Path & "\" & FE
Dim oAsm As AssemblyDocument = ThisApplication.ActiveDocument
Dim oAsmComp As AssemblyComponentDefinition = oAsm.ComponentDefinition
Dim oldPFE As String = oAsmComp.Occurrences.ItemByName(oCCPartName).ReferencedDocumentDescriptor.FullDocumentName
If Dir(PFE) = "" Then
Dim oDoc As Document = ThisApplication.Documents.Open(oldPFE, False)
oDoc.SaveAs(PFE, False)
oDoc.Close
'Return
End If
Component.Replace(oCCPartName, PFE, False)
'MessageBox.Show(oCCPartName, "Title")
Parameter(oCCPartName, "Thickness") = Thickness
iProperties.Value("Project", "Part Number") = partnum
Return
End Sub
Does anyone know why it isn't working like i hope it does ??
