- Mute
- Permalink
- Report
I would like to create a master (i)Part? that has multiple dependencies on its dimensions. When part is places in assembly,I would like for a prompt to show ask size name, which controls overall length, end length, various diameters etc. And then a second prompt asking required pressure which controls the bore diameter.
What I have tried...
- Creating an iPart, entering all the parameters in the table, placing the component in an assembly and from there selecting the member from the place table. This works but to introduce a second dependency I would have to repeat this table several times for each pressure and corresponding bore size which would work but is not neat, confusing for end user and could become an infinitely long table for parts with more than two dependencies.
- Using ilogic to request dependencies using input list boxes and then produce part. This works at part level but I can't find a trigger to run this rule when the part is placed in the assembly.
I think the second solution is the better one, I just don't know the final step to pull it off. I can't be the first person to be making a master part with multiple parameter dependencies.
Thanks for you help!
Harvey
