Placing a part in an assembly with a macro
02:17 PM
I have been working with macros basically making user forms to control the models. The program calls on a part that I use as an actuation template (its just a part with parameters that are then linked to the assembly contraints) then the macro will change the parameters and update the model.
What I need to do is to put in some code in the userforn initialize sub that gets the actuation template from the disk, for example: C:\Other Stuff\Actuation Template A.ipt. Then the macro places the part into the assembly. The userform then manipulates the actuation template (and the assembly model). Then when the userform is unloaded the part is deleted from the assembly. Thanks for any advice you can offer.
