Adding fasteners to Clearance & Thread spreadsheets
06:03 AM
I would like to add a "Shoulder Bolt" fastener (both Inch & Metric) to the Clearance.xls file so that when selected it would generate a counterbore hole the size of the shaft and a corresponding thread specific to the bolt size (all of which I can input in the table) but currently I have to do this manually by selecting a "counterbore - thru thread" condition.
Also, we use Helicoil inserts a lot and would like to add this to the Thread.xls but I need Inventor to differentiate between a standard threaded hole & the Helicoil so that the hole callout on the drawing will come in as desired.
Is there any way these can be accomplished?
Jack Pelon
Mechanical Designer
Inventor Professional 2013
