Place embedded spreadsheet on drawing as window
harvey_craig2RCUH
harvey_craig2RCUH
I am embedding a spreadsheet on my drawing using iLogic. It embeds no problem:
Dim oDrawingDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oNewExcelSheet As Object = oDrawingDoc.ReferencedOLEFileDescriptors.Add("C:\TEMP\InventorCalcs\Calc21.xlsx", 3330)
Just a niggle, it appears in the model browser which is good. However, we like to have the sheet as an linked window placed to the right of the sheet. This is the default option when you do it in the UI. How do I get the window on my sheet?
Harvey
harvey_craig2RCUH
Does anyone have an idea for this?
marcin_otręba
use:
Public Sub CreateDrawingExcelTable()
    ' Set a reference to the active drawing document
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    ' Set a reference to the active sheet
    Dim oActiveSheet As Sheet
    Set oActiveSheet = oDrawDoc.ActiveSheet
    ' Create the placement point for the table
    Dim oPoint As Point2d
    Set oPoint = ThisApplication.TransientGeometry.CreatePoint2d(25, 25)
    ' Create the table by specifying the source Excel file
    ' This assumes that the first row in the Excel sheet specifies the column headers
    ' You can specify a different row using the last argument of the AddExcelTable method
    Dim oExcelTable As CustomTable
    Set oExcelTable = oActiveSheet.CustomTables.AddExcelTable("C:\Temp\test.xls", oPoint, "Excel Table")
End Sub
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
harvey_craig2RCUH
I'm looking to have the spreadsheet as an emending rather than a table. Thanks for trying!
Cheers,
Harvey
harvey_craig2RCUH
I have also tried making the sheet visible:
Dim oNewExcelSheet As Object = oDrawingDoc.ReferencedOLEFileDescriptors.Add(TempSpreadsheetPath, 3330)
oNewExcelSheet.DisplayName = "CalcSheet"
oNewExcelSheet.Visible = True
And although this does change the variable (in the UI Visibility becomes ticked):
The CalcSheet does not appear as a window in the drawing area. How do I get the CalcSheet in the drawing area like it would be placed if this were done by the UI?
Harvey
marcin_otręba
sorry, but i am pretty sure it is not possible
