Getting part parameter of assembly placed in drawing
harvey_craig2RCUH
harvey_craig2RCUH
I would like to get parameter "E1" in part "NPT_Port" which is part of an assembly placed as a view on a drawing.
I can get to the occurrence like so:
Dim oModelDoc = ActiveSheet.View("VIEW1").ModelDocument
Dim oAssemblyDoc As AssemblyDocument = oModelDoc
Dim oPartOcc = oAssemblyDoc.ComponentDefinition.Occurrences.ItemByName("NPT_Port")
I would expect parameters to be accessed in oPartOcc as I can see patterns, constraint etc etc, where do I find parameters?
Harvey
mat_hijs
You will need to get the component definition from the component occurrence and then get the parameters from there as you would in any other component definition.
harvey_craig2RCUH
Ok, so I'm in the definition:
Dim oDef As ComponentDefinition = oPartOcc.Definition
 And inside oDef I still can't see anything relevant to parameters?:
harvey_craig2RCUH_0-1733489032440.pngharvey_craig2RCUH_1-1733489084734.pngharvey_craig2RCUH_2-1733489139721.png
Harvey
mat_hijs
I think the reason your intellisense isn't showing Parameters is because you declared it as ComponentDefinition but not as PartComponentDefinition
I think sure that you can still access the Parameters from there without declaring it specifically as PartComponentDefinition even though the intellisense doesn't show it. If you know it's a part you may as well declare it as PartComponentDefinition, that should make the intellisense work.
I can't test this right now unfortunately, but if this doesn't work you may need to use Definition.Document to get teh PartDocument and then get the PartComponentDefinition from there.
harvey_craig2RCUH
Thanks very much. I rely too much on intellisense!
