Place balloons without parts list
mat_hijs
Message 1 of 8
mat_hijs
I've written some code that places balloons in batch. It opens this form:
I can enter orientation (horizontal/vertical), a filter to define which components should be ballooned and a displacement of the balloon in the X and Y direction. The code also does some more things to the balloons like change the balloon shape based on the text length and hide the leader.
AddReference "MSInventorTools.dll"
Sub Main
	Try
		' Create a new instance of the form
		Dim oForm As New MSInventorTools.frmAutoBalloon
		' Exit the sub unless the OK button was clicked
		If oForm.ShowDialog <> System.Windows.Forms.DialogResult.OK Then Exit Sub
		' Get the data from the form
		Dim sComparisonString As String = oForm.sComparisonString
		Dim sOrientation As String = oForm.sOrientation
		Dim sDisplacementX As String = oForm.sDisplacementX
		Dim sDisplacementY As String = oForm.sDisplacementY
		' Define the balloon style
		Dim sBalloonStyle As String = "GC Balloon Part Number " & sOrientation
		' Define the displacement of the balloon
		Dim iDisplacementX As Integer = sDisplacementX
		Dim iDisplacementY As Integer = sDisplacementY
		' Set a reference to the drawing document
		Dim oDrawingDoc As DrawingDocument = ThisApplication.ActiveDocument
		' Set a reference to the active sheet
		Dim oSheet As Sheet = oDrawingDoc.ActiveSheet
		' Set a reference to the selected drawing view
		Dim oDrawingView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select Drawing View (Press Esc to cancel)")
		' If nothing is selected exit the sub
		If oDrawingView Is Nothing Then
			Exit Sub
		' Get the balloon style definition
		Dim oBalloonStyle As BalloonStyle = oDrawingDoc.StylesManager.BalloonStyles.Item(sBalloonStyle)
		' Set a reference to the main assembly referenced by the drawing view
		Dim oMainAsm As AssemblyDocument = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
		Dim oMainAsmCompDef As AssemblyComponentDefinition = oMainAsm.ComponentDefinition
		' Loop through all balloons
		For i As Integer = oSheet.Balloons.Count To 1 Step -1
			' Set a reference to the balloon
			Dim oBalloon As Balloon = oSheet.Balloons.Item(i)
			' Check if the balloon value matches the comparison string
			If oBalloon.BalloonValueSets.Item(1).Value Like sComparisonString Then
				' Delete the balloon
				oBalloon.Delete()
		Next
		' Loop through all top level occurrences in the main assembly
		For i As Integer = 1 To oMainAsmCompDef.Occurrences.Count
			' Set a reference to the occurrence
			Dim oOcc As ComponentOccurrence = oMainAsmCompDef.Occurrences.Item(i)
			' Set a reference to the occurrence document
			Dim oOccDoc As Document = oOcc.Definition.Document
			' Get the occurrence part number
			Dim sOccPartNumber As String = oOccDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
			' Get the length of the part number
			Dim iOccPartNumberLength As Integer = sOccPartNumber.Length
			' Check if the occurrence has drawing curves in the selected view and if the part number matches the comparison string
			If oDrawingView.DrawingCurves(oOcc).Count <> 0 AndAlso sOccPartNumber Like sComparisonString Then
				PlaceBalloon(oDrawingDoc, oSheet, oDrawingView, oBalloonStyle, oOcc, iDisplacementX, iDisplacementY, iOccPartNumberLength)
		Next
	Catch ex As Exception
	End Try
End Sub
Private Sub PlaceBalloon(ByVal oDrawingDoc As DrawingDocument, ByVal oSheet As Sheet, ByVal oDrawingView As DrawingView, ByVal oBalloonStyle As BalloonStyle, ByVal oOcc As ComponentOccurrence, ByVal iDisplacementX As Integer, ByVal iDisplacementY As Integer, ByVal iOccPartNumberLength As Integer)
	' Set a reference to the centerpoint of the occurrence
	Dim oOccCenterPoint As Inventor.Point = oOcc.MassProperties.CenterOfMass
	' Convert the Centerpoint of the occurrence to a point on the sheet
	Dim oPositionPoint As Point2d = oDrawingView.ModelToSheetSpace(oOccCenterPoint)
	oPositionPoint.X = oPositionPoint.X + iDisplacementX / 10
	oPositionPoint.Y = oPositionPoint.Y + iDisplacementY / 10
	' Get a drawing curve from the occurrence
	Dim oDrawingCurve As DrawingCurve = oDrawingView.DrawingCurves(oOcc).Item(1)
	' Get the midpoint of the drawing curve
	Dim oGeometryIntent As GeometryIntent
	oGeometryIntent = oSheet.CreateGeometryIntent(oDrawingCurve, PointIntentEnum.kCenterPointIntent)
	' Create an object collection for leader points
	Dim oLeaderPoints As ObjectCollection
	oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
	' Clear the leader points object collection
	oLeaderPoints.Clear()
	' Add the position point and the geometry intent to the leader points object collection
	oLeaderPoints.Add(oPositionPoint)
	oLeaderPoints.Add(oGeometryIntent)
	' Create a balloon
	Dim oBalloon As Balloon = oSheet.Balloons.Add(oLeaderPoints, , PartsListLevelEnum.kFirstLevelComponents, , oBalloonStyle, )
	' Remove the leader from the balloon
	oBalloon.Leader.AllNodes.Item(1).Delete()
	' Determine the sketch symbol to use for the balloon
	Dim sSketchSymbol As String = oBalloonStyle.Name & " " & iOccPartNumberLength
	' Set the balloon type
	Try
		' Override the balloon type based on the length of the part number
		oBalloon.SetBalloonType(BalloonTypeEnum.kSketchedSymbolBalloonType, oDrawingDoc.SketchedSymbolDefinitions.Item(sSketchSymbol))
		' Set the balloon position
		oBalloon.Position = oPositionPoint
		' Apply the default balloon type
		oBalloon.SetBalloonType(oBalloonStyle.BalloonType)
	End Try
End Sub
This all works, but only if a parts list has been placed or a balloon has been created manually before running the code. Is there a way to make this still work in these cases? I'd like to avoid having to place a parts list if possible
Replies (7)
Message 2 of 8
Stakin
Maybe you should confirmed the bom structure of the parts list or exist balloons?and set the same as it.
Message 3 of 8
mat_hijs
Do you have some code to explain what you mean?
Message 4 of 8
A.Acheson
Hi @mat_hijs
Likely you have to at the very least set the BOM structure. You could place the part lists set the bom structure and delete the part list. Any balloons placed must follow the structure you selected.
Try this manually first then mimic the same by code.
Regards
Alan
Message 5 of 8
Stakin
Please refer the Balloons_Add_Sample
Public Sub CreateBalloon()
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    ' Set a reference to the active sheet.
    Dim oActiveSheet As Sheet
    Set oActiveSheet = oDrawDoc.ActiveSheet
    ' Set a reference to the drawing curve segment.
    ' This assumes that a drwaing curve is selected.
    Dim oDrawingCurveSegment As DrawingCurveSegment
    Set oDrawingCurveSegment = oDrawDoc.SelectSet.Item(1)
    ' Set a reference to the drawing curve.
    Set oDrawingCurve = oDrawingCurveSegment.Parent
    ' Get the mid point of the selected curve
    ' assuming that the selection curve is linear. This is used to calculate the position of balloon and leader line.
    Dim oMidPoint As Point2d
    Set oMidPoint = oDrawingCurve.MidPoint
    ' Set a reference to the TransientGeometry object.
    Dim oTG As TransientGeometry
    Set oTG = ThisApplication.TransientGeometry
    Set oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
    ' Create a couple of leader points.
    Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 10, oMidPoint.Y + 10))
    Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 10, oMidPoint.Y + 5))
    ' Add the GeometryIntent to the leader points collection.
    ' This is the geometry that the balloon will attach to.
    Set oGeometryIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve)
    Call oLeaderPoints.Add(oGeometryIntent)
    ' Set a reference to the parent drawing view of the selected curve
    Set oDrawingView = oDrawingCurve.Parent
    ' Set a reference to the referenced model document
    Dim oModelDoc As Document
    Set oModelDoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
    ' Check if a partslist or a balloon has already been created for this model
    Dim IsDrawingBOMDefined As Boolean
    IsDrawingBOMDefined = oDrawDoc.DrawingBOMs.IsDrawingBOMDefined(oModelDoc.FullFileName)
    If IsDrawingBOMDefined Then
        ' Just create the balloon with the leader points
        ' All other arguments can be ignored
        Set oBalloon = oDrawDoc.ActiveSheet.Balloons.Add(oLeaderPoints)
    Else
        ' First check if the 'structured' BOM view has been enabled in the model
        ' Set a reference to the model's BOM object
        Dim oBOM As BOM
        Set oBOM = oModelDoc.ComponentDefinition.BOM
        If oBOM.StructuredViewEnabled Then
            ' Level needs to be specified
            ' Numbering options have already been defined
            ' Get the Level ('All levels' or 'First level only')
            ' from the model BOM view - must use the same here
            Dim Level As PartsListLevelEnum
            If oBOM.StructuredViewFirstLevelOnly Then
                Level = kStructured
            Else
                Level = kStructuredAllLevels
            ' Create the balloon by specifying just the level
            Set oBalloon = oActiveSheet.Balloons.Add(oLeaderPoints, , Level)
        Else
            ' Level and numbering options must be specified
            ' The corresponding model BOM view will automatically be enabled
            Dim oNumberingScheme As NameValueMap
            Set oNumberingScheme = ThisApplication.TransientObjects.CreateNameValueMap
            ' Add the option for a comma delimiter
            oNumberingScheme.Add "Delimiter", ","
            ' Create the balloon by specifying the level and numbering scheme
            Set oBalloon = oActiveSheet.Balloons.Add(oLeaderPoints, , kStructuredAllLevels, oNumberingScheme)
End Sub
Dim oBOM As BOM
Message 6 of 8
mat_hijs
Apparently it seems to work after all, I just needed to change PartsListLevelEnum.kFirstLevelComponents to PartsListLevelEnum.kStructuredAllLevels
Message 7 of 8
Stakin
I think before add balloons,it would be more reasonable to check the exists of balloons or partslist and it's bom structure. Once this is confirmed, if it does not match expectations, the balloons and partslist must be deleted.
Message 8 of 8
mat_hijs
I would say that generally you're right, but my case is very specific. I use this only for a specific type of installation drawings where the assembly will always have the same BOM structure since it comes from the same template. There will also never be a parts list on these specific drawings.
Still, thank you for the effort!
