How to set a file path for exporting DXF/ Step files
roy7BB24
roy7BB24
Hi All
Currently working on a script to automate all of my exports (DXF's, Step files etc.) at the end of a job. I've looked at the two examples below, I'm reasonably confident I can adapt everything from there to suit my needs. The only thing I'm unsure on is I would like to set the folder all of these files are exported to. Ideally it would be some kind of save as window or the like where I can browse to the folder, I want them all dropped in run the script from there. Anyone able to point me in the right direction to get started on this?
Solved: How to create flat patterns and export them to DXF from assemblies - Autodesk Community - In...
Solved: Upgrading Export DXF flat pattern from Assembly with iProperty naming - Autodesk Community -...
Kind Regards
Roydon Mackay
vpeuvion
Hi, can you try this :
Sub Main()
	Dim oFoldBrowsDialog As New FolderBrowserDialog()
	If oFoldBrowsDialog.ShowDialog() = DialogResult.OK Then
    	Dim Path As String = oFoldBrowsDialog.SelectedPath & "\"
		MessageBox.Show(Path)
End Sub
This fills the Path variable, all you have to do is add the file name.
Hope this will help you.
Vincent.
roy7BB24
Cheers, this has worked a treat, thanks for the assistance
Kind Regards
Roydon Mackay
