Place an iLogic Assembly in another assembly
darok8
darok8
Hi everyone, I'm new to iLogic and I felt the need to use ilogic to automate some of my work processes, so I made an assembly with instructions in iLogic, it's very basic (I think so)...
If ElementContact_left = "none" Then
	Component.IsActive("M22_K10:1") = False
	Component.IsActive("M22_K01:1") = False
End If
If ElementContact_left = "NO" Then
	Component.IsActive("M22_K10:1") = True
End If
If ElementContact_left = "NC" Then
	Component.IsActive("M22_K01:1") = True
End If
Prior to the code, make the variable "ElementContact_left" and add a new "level of detail" called iLogic, and the code works fine for me in the same assembly, but at the time of said assembly, insert it through "place ilogic component" in another assembly, I It throws an error message that it can't find the piece to leave unsuppress, I don't know what I'm missing, I hope it was clear...
A.Acheson
Hi @darok8
What is needed is to stabilize the occurrence name so the code reference this static name and not the occurrence name which under normal circumstances changes when the filename is change.See this article for extra explanation of what is happening
Component.IsActive("M22_K10") = False
Edit:
On further reading your model still has the same occurrence name. Is this the case?
Regards
Alan
darok8
Hi @A.Acheson
Oh I understand, thank you for the answer
darok8
Hi @A.Acheson
