Place all design views on an idw
dan_inv09
Advisor Advisor
dan_inv09
I need to find a good book or a class or something to learn iLogic. I really don't even know how to start something. I've copied and pasted from other peoples stuff, but it's mostly blind luck if it works.
I have an assembly, it has a design view for each part which only shows that part. I want to place a view in my idw of each design view.
I don't need then spaced out or anything, I can position them myself later - they can all be stacked one on top of the other in the bottom corner or wherever. While I don't need the master view and maybe one or two other views that may have been created in the assembly getting rid of them manually is not a problem.
I've found things for doing stuff to drawing views, but I can't seem to find how to create one.
(And then I've got to figure out how to find all the assembly views and go through them one by one.)
Curtis_Waguespack
Just giving this a bump and linking it to the other thread of the same topic:
http://forums.autodesk.com/t5/inventor-general-discussion/place-all-design-views-on-an-idw/m-p/60363...
