Picking sketch line from drawing
sellis
sellis
VB.NET with VS2010, Inventor 2012
I have a drawing view of a part with a sketch that contains some lines. I need to pick one of the sketch lines.
I can pick a line with sketch active using the kSketchCurveLinearFilter
I have not been able to pick it from outside of sketch. Have tried using kDrawingCurveSegmentFilter to get a DrawingCurveSegment but I can not get the sketch line from the DrawingCurveSegment
I assume there is a way to get the sketch line from DrawingCurveSegment or DrawingCurveObject but have not figured it out.
A sample would be great.
Stan
amitnkukanur
i did this and hope this helps you. I have a Assembly and place a part to it(with *.ipt extension)
and this below code in new Sub
    Public Sub New()
        ' This call is required by the designer.
        InitializeComponent()
        '//start Inventor through code
        Dim started As Boolean = False
        Try
            Dim InvType As Type = GetTypeFromProgID("Inventor.Application", True)
            selectedSample = CreateInstance(InvType)
            selectedSample.Visible = True
            started = True
        Catch ex As Exception
            MessageBox.Show(ex.ToString())
        End Try
    End Sub
double click in a button on form and add this code
 Dim asmDoc As AssemblyDocument
        asmDoc = selectedSample.ActiveDocument
        If asmDoc.SelectSet.Count = 0 Then
            MessageBox.Show("No item selected")
        End If
        selSelected = asmDoc.SelectSet
        Dim CompOccurance As ComponentOccurrence
        Dim obj As Object
        For Each obj In selSelected
            CompOccurance = obj
            CompOccurance.Visible = False
        Next
this will select a line and makes its visibility false
Senior Software Engineer
sellis
Thanks but that is not quite what I am doing.
This is an idw file with a sketch and I need to select a line from the sketch without having the sketch open for editing. I believe I need to select a DrawingCurveSegment and somehow get the sketch line from that.
Stan
sellis
Errr.... never mind
DrawingCurveSegment.Parent.ModelGeometry returns the sketch item.
