Phantom cause error in my I logic code , is there a way to fix it ?
Darkforce_the_ilogic_guy
Advisor Advisor
I am Looping through an assambly  bom Stuctured , with Ilogic to get date form the componemt/part Assambly  but if someone have use Phantom I get this error. Is there a way to get it to work  ?kinder of workaround ?
Ralf_Krieg
Hello
Can you explain a little bit more detailed. You traverse through the rows of the structured BOMView. What do you try to get from the BOMRow?
There is a property "Promoted" who's value is true if the BOMRow is promoted e.g. by a parent subassembly is a phantom, otherwise it's false.
R. Krieg
RKW Solutions
www.rkw-solutions.com
I am trying to get information (properties form the BOM to excel ) and to see if the model have a drawing and a lot more. The project is very complete but I think most of it will just to noise. To add here. The code just error then it try to get data form files that are part of an phantom assembly
Ralf_Krieg
Hello
And what kind of infomation did you try to access? If you can't give detailed information, the only solution would be that you strip your code down to the failing part by yourself until you found it or enclose your failing part code in a try-catch statement to suppress the error messages.
As an example i traverse through the structured BOM view, get item number, quantity and two iProps for each row and write it to the iLogic logger. Even if there are promoted parts in the BOM view, no error is raised. Can you confirm that with your assembly or is it failing also?
Sub Main()
	BOMDemo()
End Sub
Private Sub BOMDemo()
	'Makro assumes:
	'- an assemblydocument is open
	'- the structured BOM view is activated
	Dim oApp As Inventor.Application
	oApp = ThisApplication
	Dim oAssDoc As AssemblyDocument
	oAssDoc = oApp.ActiveDocument
	Dim oBOM As BOM
	oBOM = oAssDoc.ComponentDefinition.BOM
	oBOM.StructuredViewEnabled = True
	Dim oBOMView As BOMView
	For Each oBOMView In oBOM.BOMViews
		If oBOMView.ViewType = BOMViewTypeEnum.kStructuredBOMViewType Then Exit For
	Next
	If oBOMView Is Nothing
		MsgBox("BOMView not found", , "iLogic")
		Exit Sub
	End If
	Dim oBOMRow As BOMRow
	'BOM headline
	Logger.Info("Item | Quantity | Part Number | Description")
	Logger.Info("-------------------------------------------")
	'read all BOM rows
	For Each oBOMRow In oBOMView.BOMRows
	    Logger.Info(" " & oBOMRow.ItemNumber & "     | " & oBOMRow.ItemQuantity & "           | " & oBOMRow.ComponentDefinitions.Item(1).Document.PropertySets.Item("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").Item("Part Number").Value & "  |  " & oBOMRow.ComponentDefinitions.Item(1).Document.PropertySets.Item("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").Item("Description").Value)
		If oBOMRow.ChildRows IsNot Nothing Then TraverseBOM(oBOMRow.ChildRows)
	Next
End Sub
Private Sub TraverseBOM(oBOMRows As BOMRowsEnumerator)
	Dim oBomRow As BOMRow
	For Each oBomRow In oBOMRows
		Logger.Info(" " & oBomRow.ItemNumber & "     | " & oBomRow.ItemQuantity & "           | " & oBomRow.ComponentDefinitions.Item(1).Document.PropertySets.Item("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").Item("Part Number").Value & "  |  " & oBomRow.ComponentDefinitions.Item(1).Document.PropertySets.Item("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").Item("Description").Value)
	Next
End Sub
R. Krieg
RKW Solutions
