Performance Issues
Performance Issues
bravaiser
Message 1 of 1
Performance Issues
bravaiser
I created a tool where User Coordinate System (UCS) is defined on top of a surface. I use hundreds of these UCS to create a sketches as the basis for a set operation either a join or a cut. The problems happens after the first 100 features the systems slows down considerably. Is this an actual behaviour ? How can I speed up the process ?.
I have made some tests breaking down the process and adding features 50 at the time but still the problem persists.
My loop is something like this
for ( i = 0  to number_of_elements_in_pattern)
  create UCS
  create a sketch on XY plane
  create a solid of revolution
  add a solid to the geometry
In this pseudo code if number_of_elements_in_pattern is bigger than 100 the creation of features happens too slow, in a case where I had 750 features it took 3 hours, which is incredibly slow. I can not figure out the real issue.
Any ideas
Thank you
Replies (0)
