PDF rule does not work anymore with newer INVENTOR
vkulikajevas
vkulikajevas
PDF export rule used to work, now shows "Invalid Point" Error and no PDF is created
oPath = ThisDoc.Path
'msgbox(oPath)
oFileName = ThisDoc.FileName(False)
oRevNum = iProperties.Value("Project", "Revision Number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 0
oOptions.Value("Vector_Resolution") = 4800
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
'oFolder = oPath & "\PDF"
'If Not System.IO.Directory.Exists(oFolder) Then
'    System.IO.Directory.CreateDirectory(oFolder)
'End If
oDataMedium.FileName = oPath & "\" & ThisDoc.FileName(False) & ".pdf"
'MsgBox(FileName)
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
rhasell
Hi
A few versions ago, something changed, but I can't remember what it was, the PDF export stopped working, this was quickly fixed by the forum members.
I have updated your code with a merged extract from mine, I changed the resolution from 4800 to 400, again something changed with version 2022, and the resolution started working correctly. Therefore, 4800 resolution starts creating huge files, which for the most part is not necessary. You can change it back again if desired.
Dim oDoc As Document
oDoc = ThisDoc.Document
Dim oPDFAddIn As TranslatorAddIn
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
Dim oDocument As Document
oDocument = ThisDoc.Document
Dim oContext As TranslationContext
oContext.Type = kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap
Dim oDataMediumPDF As DataMedium
oDataMediumPDF = ThisApplication.TransientObjects.CreateDataMedium
'--PDF settings---
'If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
If oPDFAddIn.HasSaveCopyAsOptions(oDoc, oContext, oOptions) Then
	oOptions.Value("All_Color_AS_Black") = 0
	oOptions.Value("Vector_Resolution") = 400
'---End PDF settings
oFileName = ThisDoc.FileName(False) 'without extension
oDataMediumPDF.FileName = oPath + "\" + oFileName & ".pdf"
'Check for Existing File
If System.IO.File.Exists(oDataMediumPDF.FileName) Then
	oChoice = MessageBox.Show(oDataMediumPDF.FileName & " Already Exists - Overwrite?", "Title", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
	If oChoice = 7
		'MessageBox.Show("exit", "Title")
		Return
	Else
		'MessageBox.Show("Overwrite", "Title")
'''--- Publish document.
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMediumPDF)
Reg
2026.1
rhasell
Hi
Found the change. it was in the PDF settings IF statement
The oDataMedium statement needed to change.
added the oDoc definition
Here is your original code with the fix.
'msgbox(oPath)
'End If
'MsgBox(FileName)
Reg
2026.1
