.PDF Generator with Inventor 2020
We recently migrated from Inventor 2017 to Inventor 2020.  With 2017 we were using a .PDF generator that read the iPropertyTAG on the IDW file and created a .PDF file and folder location for each tag.  Each of those .PDF Bundles were then printed by the TAG for that specific group.
With the recent upgrade to Inventor 2020, the iPropertyTAG is there, the .PDF Generator Add-In is loaded but when we run the scan there are no TAGS found.
Was there something that changed from Inventor 2017 to Inventor 2020 that would cause this process to fail?
Donna
WCrihfield
What do you mean by iPropertyTAG or TAG?  Does TAG stand for something?
Does your addin search for a specific standard iProperty or a custom iProperty?
Are you talking about an XML tag?
Wesley Crihfield
(Not an Autodesk Employee)
