passing parameters from main assembly to sub-assembly INSIDE another sub-assembly ??
doug.johnston
doug.johnston
Hey folks,
I have a sub-assembly, inside another sub-assembly, that I want to pass parameters & iproperties from the main assembly.
I want to pass the values from the Cxxxxx_OVxxxxCAAA.iam (main assembly) to the TOP FRAME RELIEF LID FRAME_1.iam assembly, which is inside the TOP FRAME_STRUCTURAL assembly,
I've been using the following to pass the values from the main assembly to a sub-assembly:
Parameter("C_TOP FRAME_master sketch", "LOAD_WIDTH") = LOAD_WIDTH
What code can I use to resolve this ??
It's not easy maintaining this level of insanity !!!!!
theo.bot
It should work in the way you described, so I don't get your real question. Is it not working for you? do you want an alternative way?
