PartsList Title and Header Height
ilyas_adnm
ilyas_adnm
Hi Everyone,
I'm writing a function to position my PartsList based on the lower right corner. The Position property controls the position from the top right corner. Hence, to do this, I'll need the height of the PartsList. I can get the total height of the rows. However, I can't seem to find the height for the title and header. Does anyone any idea?
Sub Main()
	Dim oSheet As Sheet = ActiveSheet.Sheet
	For Each oPartsList As PartsList In oSheet.PartsLists
		MovePartsList(oPartsList,0,0)
	Next
End Sub
Sub MovePartsList(oPartsList As PartsList, x As Double, y As Double)
	oPartsList.Position=ThisApplication.TransientGeometry.CreatePoint2d(x,y+getPartsListHeight(oPartsList))
End Sub
Function getPartsListHeight(oPartsList As PartsList) As Double
	getPartsListHeight = 0
	getPartsListHeight += 1.178 'supposed to get the header and title heights, however, can't seem to find it in api. Hence, just putting a fixed value here
	For Each oRow As PartsListRow In oPartsList.PartsListRows
		getPartsListHeight += oRow.Height
	Next
End Function
Regards
Ilyas
FINET_Laurent
Hi @ilyas_adnm,
You could use the rangebox property instead. The folowing code gives you the height of the table h :
Dim p As Inventor.PartsList = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingPartsListFilter, "Pick a parts list")
Dim h As Double = p.RangeBox.MaxPoint.Y - p.RangeBox.MinPoint.Y
MsgBox(h)
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Andrii_Humeniuk
Hi @ilyas_adnm . Simple code for positioning the PartsList on the TitleBlock:
Dim oDoc As Document = ThisDoc.Document
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
If Not TypeOf oDoc Is DrawingDocument Then Exit Sub
Dim oDrawDoc As DrawingDocument = oDoc
Dim oLists As PartsLists = oDrawDoc.ActiveSheet.PartsLists
If oLists.Count = 0 Then Exit Sub
Dim oBlick As TitleBlock = oDrawDoc.ActiveSheet.TitleBlock
Dim oList As PartsList = oLists(1)
Dim dW As Double = oList.RangeBox.MaxPoint.X - oList.RangeBox.MinPoint.X
Dim dH As Double = oList.RangeBox.MaxPoint.Y - oList.RangeBox.MinPoint.Y
oList.Position = oTG.CreatePoint2d(oBlick.RangeBox.MinPoint.X + (dW), oBlick.RangeBox.MaxPoint.Y + (dH))
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
ilyas_adnm
Hi @Andrii_Humeniuk,
Thanks for the sample. I've modified my function to use the RangeBox instead.
	oPartsList.Position = ThisApplication.TransientGeometry.CreatePoint2d(x, y + oPartsList.RangeBox.MaxPoint.Y-oPartsList.RangeBox.MinPoint.Y)
End Sub
Regards
Ilyas
