Parts List Find and Replace - if then cell equals
andrew_canfield
Message 1 of 8
andrew_canfield
Hello.
This will find & replace but I'd also like to alter the next column cell value if a criteria is met:
how can oCell.Value be edited?
If Column Description = "M4 FORM A WASHER"
then
Material Column = " BS EN ISO 7089:2000"
Dim oPartslist As PartsList
oPartslist = oSheet.PartsLists(1)
            Dim ic As Integer
            For ic = 1 To oSheet.PartsLists.Count
                 oPartsList = oSheet.PartsLists.Item(ic)
            Next
            Dim i As Long
            For i = 1 To oPartsList.PartsListRows.Count
                Dim oRow As PartsListRow
                 oRow = oPartsList.PartsListRows.Item(i)
                ' Iterate through each column in the row.
                Dim j As Long
                For j = 1 To oPartsList.PartsListColumns.Count
                    ' Get the current cell.
                    Dim oCell As PartsListCell
                     oCell = oRow.Item(j)
'                    ' Check that the column isn't the quantity column.
'                    If oPartslist.PartsListColumns.Item(j).Title = sColumnTitle Then
'						xx = oRow
'						yy = j
'						MessageBox.Show(xx, yy)
                        If oCell.Value = "M4 FORM A WASHER" Then
                            oCell.Value = "M4 FORM A WASHER C.S BZP"
                            oCell.Static = True
'                    End If
                Next
            Next
Regards
Andrew
Replies (7)
Message 2 of 8
A.Acheson
Within the filter checking the cell for matching criteria declare a new cell and index over by one column keeping on the same row.
Dim oCell1 As PartsListCell
                     oCell1 = oRow.Item(j+1)
Regards
Alan
Message 3 of 8
andrew_canfield
kinda fixed:
Dim oDoc As Inventor.DrawingDocument
oDoc = ThisDoc.Document
Dim oSheet As Inventor.Sheet
oSheet = oDoc.Sheets(1) ' first sheet
'oSheet = oDoc.Sheets("A0:1") ' sheet by name
' say there is a Partslist on the sheet.
            Dim ic As Integer
                 oPartslist = oSheet.PartsLists.Item(ic)
            Next
            Dim i As Long
            For i = 1 To oPartslist.PartsListRows.Count
                 oRow = oPartslist.PartsListRows.Item(i)
                Dim j As Long
                For j = 1 To oPartslist.PartsListColumns.Count
                        If oCell.Value = "M4 FORM A WASHER C.S bzp" Then
                            'oCell.Value = "M4 FORM A WASHER C.S BZP"
                            oCell.Static = True
					j=5
                     oCell.Value = "BS EN ISO 7089:2000"
                            oCell.Static = True
                Next
            Next
Message 4 of 8
andrew_canfield
What's needed to edit the content of a cell if there's a a partial match?
i.e. cell = "M4 FORM A WASHER CARBON STEEL BZP" & replace "CARBON STEEL BZP" with nothing.
( so cells containing M5, M6,etc will also be edited & the specification will overwrite the material column - & the specification also references the material)
Regards
Andrew
Message 5 of 8
andrew_canfield
Thanks Again
Is it possible to have just part of the text replaced within a cell?
eg use replace "CARBON STEEL BZP" with ""
so
becomes
M4 FORM A WASHER
(so one line of code can convert M4, M5, M6 etc)
Regards
Andrew
Message 6 of 8
A.Acheson
Sure, if you get a hold of the string object there are loads of built in functions to work with the string.
Enter "Replace" and then hover over the area and a description of how to use it will pop up in the tool tip.
Dim oDesc_old As String
Dim oDesc_new As String
oDesc_old = "M4 FORM A WASHER CARBON STEEL BZP"
oDesc_new = oDesc_old.Replace("CARBON STEEL BZP", "")
MessageBox.Show(oDesc_new, "Title")
Regards
Alan
Message 7 of 8
andrew_canfield
Seeing problems when trying to combine the two -  can the cell contents be seen as a string (my guess, & it is a total guess). Added comments after the ' IN CAPITALS  LINE 34- hope they help.
            Dim ic As Integer
            Next
            Dim i As Long
                Dim j As Long
						oDesc_old = oCell ' THIS CREATES AN ERROR - GUESS oCell ISN'T A STRING?
						MessageBox.Show(oDesc_old, "oCell") ' THE MESSAGE BOX WILL NOT DISPLAY oCell - BECAUSE IT'S NOT A STRING?
					 	oCell = oDesc_new
'                        If oCell.Value = "M4 FORM A WASHER C.S bzp" Then ' GUESS THE IF WILL NOT BE NEEDED AS EDITS SHOULD UPDATE
'                            'oCell.Value = "M4 FORM A WASHER C.S BZP"
                            oCell.Static = True
                        'End If
                Next
            Next
 Regards
Andrew
Message 8 of 8
A.Acheson
oCell on it's own wouldn't be a string but  oCell.Value would be.
Regards
Alan
