Connecting two points with a 3D sketch
t_gawlik
t_gawlik
I am an iLogic beginner. I would like to use iLogic rule to connect two specific points (A1 and B1) by 3d sketch. My guess is that the rule must first create this sketch "Sketch 1" in the browser history and then connect these points with a line.
I don't know how to go about this, can you help?
JelteDeJong
try this rule. You can run it and select 2 work points.
Dim doc As PartDocument = ThisDoc.Document
Dim def As PartComponentDefinition = doc.ComponentDefinition
Dim wpA1 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPointFilter, "Select work point A1")
Dim wpB1 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPointFilter, "Select work point B1")
Dim sketch3D As Sketch3D = def.Sketches3D.Add()
sketch3D.SketchLines3D.AddByTwoPoints(wpA1, wpB1)
Jelte de Jong
Blog: hjalte.nl - github.com
t_gawlik
Thanks  JelteDeJong
Very close to the final result
There will be more points in the future (A1 B1, A2 B2 ... An Bn) and they will be generated as a list (array?) or something similar. I don't want to point them manually but want the 3D sketch to connect them automatically
